BUILD-OFF CHALLENGE: Another 914-GT Conversion Project, I finally drove it this weekend! |
jkb944t |
Apr 14 2011, 05:55 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I am working on restoring a 1973 914 and converting it to a GT clone with the flares and chassis stiffening. Here is a picture of where I am on it.
Jeff B Attached image(s) |
jkb944t |
Jul 13 2015, 06:05 AM
Moved to the front of the car and removed the front bumper support that was slightly bent most likely from a previous fender bender. Media blasted the surface rust and then applied epoxy primer then welded the bumper support back in.
Applied epoxy primer to the inside of the new fender section before spending many hours lining it up with the door gap and fender flare. Thanks to everyone for their input on setting this gap. I finally welded the fender to the flare and finish ground the weld. Still have to finish all the spot welds around the outside of the fender section. Then the next step is to put the rear trunk back on and figure out where to locate the hinge support that is broken off. Not looking forward to this step for some reason. Jeff B |
Lo-Fi Version | Time is now: 10th May 2024 - 12:37 PM |
