undercoating question, around the door handle |
Apr 27 2011, 09:01 PM
so,
I am replacing an area around the door handle and lower targa bar. The original area, and the part I am using were filled with a ton of seam sealer, then undercoating. No spray foam in that area...but it was all around the vent tube... Its all cleaned out of both the car and the new piece. What would you suggest I use in place of that solution... No foam here... Once I get it welded in place, I will not be able to get in there to well, and I dont wnat anything on there while welding...it will just contaminate what I am doing.. I need all my magic welding mojo for this one..door pillar, handle area...its gonna take some grinding when I get done...lots of nooks and crannies to deal with...yippee. I will post a few pics when I get everything prepped, then welded, the ground down... Rich |
Lo-Fi Version | Time is now: 19th May 2024 - 07:44 PM |
