Jack Stand Locations, Best/safest spots |
roundboy914 |
May 19 2004, 08:26 PM
Member Group: Members Posts: 210 Joined: 16-October 03 From: Chicago, IL Member No.: 1,251 |
With all this talk of our cars on jack stands, i was wondering the best spots for the stands to be placed. I usually place the front pair right back of the front wheels, in the side channel on the floor (right inside of the rocker panel). The rear set, i put underneath the engine mountaing bar. Car seems balanced (doesn't move when i'm hauling my 300 pound carcass in and out while bleeding the brakes), i just wonder if it is the best spot.
ChrisReale |
May 19 2004, 08:32 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
I put the rears on the engine mount bar and the fronts on the a-arms where the bearings are (the ones closer to the rear)
415PB |
May 19 2004, 09:05 PM
Member Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 |
QUOTE(ChrisReale @ May 19 2004, 06:32 PM) I put the rears on the engine mount bar and the fronts on the a-arms where the bearings are (the ones closer to the rear) Me too |
URY914 |
May 19 2004, 09:12 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,389 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I don't use jackstands.
I just lift up the car with one hand, and fix what broken with the other. (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/cool_shades.gif) Paul |
Elliot_Cannon |
May 19 2004, 09:39 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
Just lean it up on one side then prop it up with a couple 4X4s. (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif)
Cheers, Elliot |
boxstr |
May 19 2004, 11:38 PM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
There is an article in the new Excellence August,on this very subject. It even has pictures.
CCLINALIFTINGEXPERIENCE |
Levi |
May 19 2004, 11:43 PM
Lick my nuts Group: Benefactors Posts: 623 Joined: 11-March 04 Member No.: 1,783 |
QUOTE(Elliot Cannon @ May 19 2004, 07:39 PM) Just lean it up on one side then prop it up with a couple 4X4s. (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) Cheers, Elliot (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/lol2.gif) (IMG:style_emoticons/default/lol2.gif) (IMG:style_emoticons/default/lol2.gif) (IMG:style_emoticons/default/chairfall.gif) |
ArtechnikA |
May 20 2004, 04:41 AM
i don't have an engine mount bar...
in the back, i usually use the front trailing arm mounts and in front, the A-Arms. unless i'm doing suspension work, in which case, that's what the donuts are for ... in Olden Tymes when jackstands were tubular, the round support tubes (once you pulled the inserts) were perfectly sized. now that pretty much all we have to choose from are the Chinese cast-iron square ratchet versions they don't fit quite as well, but i still feel safe enough ... |
tat2dphreak |
May 20 2004, 08:16 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
in the front I am using the round support piece that goes across, under the steering rack... (is that bad?)
in the back, the engine mount bar... I Don't feel safe putting jackstands on the little donut jack points, the shapes just don't match up! I'm glad someone asked this question, I've been curious, but never remember to ask boxtr, can you scan that excellece article and post? |
ArtechnikA |
May 20 2004, 08:57 AM
QUOTE(tat2dphreak @ May 20 2004, 06:16 AM) in the front I am using the round support piece that goes across, under the steering rack... (is that bad?) only to the extent that you may be driving around without the lower cover in place, which really ought to be there. if it's necessary to drive without it, you should replace the mounting hardware, becuase the little braces do add some structural strength. if you remove the access cover every time you need to put the car on stands, more power to you, but that's more work than i ever had the inclinition for... |
tat2dphreak |
May 20 2004, 09:09 AM
QUOTE(ArtechnikA @ May 20 2004, 08:57 AM) QUOTE(tat2dphreak @ May 20 2004, 06:16 AM) in the front I am using the round support piece that goes across, under the steering rack... (is that bad?) only to the extent that you may be driving around without the lower cover in place, which really ought to be there. if it's necessary to drive without it, you should replace the mounting hardware, becuase the little braces do add some structural strength. if you remove the access cover every time you need to put the car on stands, more power to you, but that's more work than i ever had the inclinition for... I don't have an access cover... is THAT bad?! |
75boxster |
May 20 2004, 11:43 AM
Member Group: Members Posts: 89 Joined: 1-January 04 From: Ft. Collins, CO Member No.: 1,488 |
I was going to install and aluminum cross bar on my car and it does
not have those braces?!? Are the needed for anything other than holding the access cover on? |
ArtechnikA |
May 20 2004, 12:06 PM
QUOTE(75boxster @ May 20 2004, 09:43 AM) I was going to install an aluminum cross bar on my car and it does not have those braces?!? they're part number 911.341.031.01 and they bolt onto the alloy crossmember. if i were using an alloy crossmember (something which is starting to appear more likely, in the 911, than it did for a long time, for a variety of reasons ...) i'd get a pair and use them... YMMV the access panel helps keep crap out of the master cylinder and steering rack area, and probably cleans up ithe underbody aerodynamics a bit. Porsche didn't put any parts on a car they didn't think they had a reason (notice i didn't say 'good reason') to -- there are some issues with undertrays in the 996's - but a 914 is not a 996 ... |
mightyohm |
May 20 2004, 12:47 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
Is there a good place to jack the car that will raise the whole back end?
I am getting tired of jacking by the jack posts with that stupid adapter that tries to slip off the jack as soon as the car is raised a few pumps... One of these days the car is going to slip off the jack and throw the 2x4 that is on the jackpad at me. I am not looking forward to it. I can't jack by the donuts because that is where I usually put my jackstands. |
ArtechnikA |
May 20 2004, 12:50 PM
QUOTE(jkeyzer @ May 20 2004, 10:47 AM) Is there a good place to jack the car that will raise the whole back end? transmission - under the diff carrier. use a good pad and make sure your transmission and engine mounts are in good shape, but if so - shouldn't be a problem ... |
i love porsche |
May 20 2004, 01:25 PM
Senior Member Group: Members Posts: 1,547 Joined: 6-May 04 From: Nutley, NJ Member No.: 2,030 Region Association: North East States |
heres the page from the article in Excellence of the 914...if you want i can post the whole article..its got good advice on jacking the car in other areas too
Attached thumbnail(s) |
tat2dphreak |
May 20 2004, 02:10 PM
that looks like it's pointing to the donuts... are there other jackstands that fit in/on the donuts? the tops of mine are sahped like a rocking horse leg (kinda flat and thin with aslight dugout...
watsonrx13 |
May 20 2004, 03:44 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Wayne, I use the donuts on the front. This also shows how these jack stands fit perfectly into the donuts, I got a set at Sears and another set at Walmart.
Attached image(s) |
watsonrx13 |
May 20 2004, 03:45 PM
Here's a shot of them holding up the rear.
Attached image(s) |
watsonrx13 |
May 20 2004, 03:47 PM
Finally, here's a shot of all four. I have had the car on these jack stands for about 6 months, I've removed the engine, transmission, front and rear suspension. The car is very stable using the jack stands this way.
Attached image(s) |
Lo-Fi Version | Time is now: 4th May 2024 - 11:20 PM |
