removing rear hub, just like the pelican article |
d914 |
May 23 2004, 07:11 PM
Re-doing the back axles, putting on longer studs on, rr rear bearings, new cvs etc.... The one side comes out like a dream, the other frigging GD piss poor exused for a hub will not move..
Back to the article, just like theirs,,,,,,,,,,,,now trying to take out the bearing carrier,,,,,,,,,, after two trips to home depot and lowes and NEITHER carries a offset wrench,,,,,,,,, Back to Harbor freight tomorrow. (,,,,,,,,,) fill in normal New jersey adjectives bright side I picked up my 46 webers and some misc pieces from a buddy today. Whole car ready for re assembly after I get this god damn flange offffffff... |
Brad Roberts |
May 23 2004, 07:14 PM
Two words:
Air Chisel. Takes 10 seconds to pop out the bearings or the hubs. I use a blunt bit so as not to damage the hub itself. Show us with some pics. B |
d914 |
May 23 2004, 07:32 PM
three words
don't have one do have a baby sledge, hasn't moved. Was going to try taking out the whole thing and separate later. Pics on the way |
d914 |
May 23 2004, 07:44 PM
tools of violence
d914 |
May 23 2004, 07:45 PM
inside hub, sorry new camera
d914 |
May 23 2004, 07:46 PM
outside
d914 |
May 23 2004, 07:54 PM
the garage
d914 |
one more time
d914 |
May 24 2004, 10:24 AM
I seen some discussions on the make of bearings..
Are SKF's ok or should I track down the FAG's??? |
thesey914 |
May 24 2004, 10:53 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
Use heat penetrating oil and keep pounding (IMG:style_emoticons/default/smash.gif)
It'll plop right out |
airsix |
May 24 2004, 12:25 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Drill some holes in a piece of plate so you can attach it to your hub with the lug bolts. A triangle-shaped piece with three holes for three lug-bolts should do. Drill a hole in the center of the plate so you can attach your slide-hammer. A few whacks with the slide hammer and the hub should pull out.
-Ben M. |
Eric_Shea |
May 24 2004, 01:26 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Beat the Fuch out of it. (IMG:style_emoticons/default/smash.gif)
MattR |
May 24 2004, 03:39 PM
I tried all sunday to get my hubs out for a 5 lug conversion, but I really busted up my finger and almost took out my fender too (IMG:style_emoticons/default/smash.gif) ...
Im going to give it another shot on saturday though. Any suggestions? I was thinking of using heat, but it seems like if I used heat on the hub, it would expand into the bearing and have the adverse affect. I tried a piece of bar stock from the back side hammer it out with. My engine is out so i have more access then normal. Would a piece of barstock turned down in the center to fit inside the hub and with an OD of the hub (smaller then the bearing ID) work with enough force? |
Bigbohr |
May 24 2004, 03:55 PM
Superlurker Group: Members Posts: 224 Joined: 19-September 03 From: Houston, TX Member No.: 1,176 |
Haven't tried the airchisel option, but a big hammer works. You need 5 or more lbs hammer. Tried 3 lbs deadblow first but that's too wimpy. Use a correct size socket and extension as recommended in the Pelican article.
On one side, the outside inner race of the bearing still came out with the hub . Guess it was locked/rusted to the hub. Gonne be fun getting that off. To get everything back together, the method in the Pelican article works like a charm (threaded bar + 2 bolts/washers + 2 sockets). |
lapuwali |
May 24 2004, 04:03 PM
QUOTE was thinking of using heat, but it seems like if I used heat on the hub, it would expand into the bearing and have the adverse affect. If you heat something with a round hole in it, the hole gets bigger, not smaller. It doesn't "expand into" the hole. The best way to visualize this is imagining the item as beads on a string. Arrange the string into a circle. If you heat it, the bits of string between the beads get longer, so the beads move away from each other, and the hole in the center gets larger. |
d914 |
May 24 2004, 04:21 PM
Airsix your a Genius.
used a spacer turned backwards for clearence and five lug nuts and the slide hammer. 10-15 shots and it was out. after 2 days of pounding from behind.... owe you a beer (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) |
MattR |
May 24 2004, 04:31 PM
Oh, you're right. I'll try heat again. I remember something about thermal expansion, but I forgot which way it went. My physics book says "imagine the hole were filled with the material."
Oh well, it looks like Im going to have to scrounge up a piece of metal to drill out and use. Good tip! |
airsix |
May 24 2004, 05:14 PM
QUOTE(d914 @ May 24 2004, 02:21 PM) Airsix your a Genius. used a spacer turned backwards for clearence and five lug nuts and the slide hammer. 10-15 shots and it was out. after 2 days of pounding from behind.... owe you a beer (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) Greg, I'm glad to hear that! I've been telling people for 4 years that this is the way to get those hubs out without beating up yourself and the hub. I think you're the first person who listened! Thanks! -Ben M. |
cgnj |
May 24 2004, 05:31 PM
Senior Member Group: Members Posts: 627 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Hi,
Went through the same thing when I did my 5 lug conversion. Ben gave me the same advice. Works like a charm. Carlos |
airsix |
May 24 2004, 05:45 PM
QUOTE(cgnj @ May 24 2004, 03:31 PM) Hi, Went through the same thing when I did my 5 lug conversion. Ben gave me the same advice. Works like a charm. Carlos Thanks Carlos! (IMG:style_emoticons/default/wavey.gif) -Ben M. |
Lo-Fi Version | Time is now: 9th June 2024 - 02:13 AM |
