Help needed-74 914 ignition switch removal |
PBC914 |
May 3 2011, 01:34 PM
Member Group: Members Posts: 192 Joined: 30-December 10 From: Minneapolis Member No.: 12,545 Region Association: Upper MidWest |
I pulled the steering wheel, removed the four screws and slid the column with the turn signal/washer/wiper out, removed a hex nut, and still cannot slide the ignition switch out. I can slide it 1/8" but it seem like there is another part I need to remove. What am I missing?
TheCabinetmaker |
May 3 2011, 02:20 PM
This is from memory, and its been a while (and i'm old), so I may be wrong, but I think there is a release in a little hole close to the nut you removed. Push it with a small screwdriver, and pull on the switch. Hope thats it, if not, Crusty's gonna scold me!!!!!
jt914-6 |
May 3 2011, 02:59 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
benalishhero |
May 3 2011, 03:17 PM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
Think you need the key in it to remove it.......
tscrihfield |
May 3 2011, 03:27 PM
Drive Fast and Take Chances Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None |
PBC914 |
May 3 2011, 04:30 PM
Thanks everyone. I ended up having to pull the four hex nuts under the dash holding the steering column and pulled it out. I tapped off the out cover, and then everything fell apart and was able to insert a new ignition switch, which solved my problem of not being able to turn the key.
Paul |
Lo-Fi Version | Time is now: 19th May 2024 - 07:43 PM |
