engine electrical questions |
matteyp |
May 4 2011, 04:40 PM
Nothing a little JB Weld can't fix... Group: Members Posts: 263 Joined: 8-June 09 From: WA Member No.: 10,450 Region Association: Pacific Northwest |
Can someone tell me what these particular connections are and where they go? im a little stumped, thanks for the help guys
type47 |
May 4 2011, 05:14 PM
Looks like your engine is a 1.7 w/D-Jet (from the 2nd pic of the air cleaner stand. This info helps people to find your answers. You can put that info in a signature). There is an AAR in the second pic. Not sure what you're indicating in the 1st pic but there is a connector to the taco plate in the area under the battery, maybe that's what you're indicating.
windforfun |
May 4 2011, 05:17 PM
Senior Member Group: Members Posts: 1,795 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
First pic shows connector for oil pressure sensor which you don't have.
matteyp |
May 4 2011, 06:26 PM
ok sorry yes, car is a 1.7 with D-jet. Soo first pic oil pressure sensor no need to worry about that? Ok in the second pic im trying to figure out where that red wire goes which it looks like its coming from the AAR. Third pic is a plug which is in the same loom as the ignition wires. Where does that one go? Thanks
May 4 2011, 09:04 PM
First pic: Plug is for the oil temp sensor.
Second pic: The red wire is from the bottom of the AAR. Third pic: The wire is from the relay board and is hooked up to the fuel pump circuit. (Verify that with a voltmeter; look for +12V for ~1.5 seconds when the key goes from off to on.) It gets plugged into the red wire. --DD |
euro911 |
May 4 2011, 09:53 PM
Check on Jeff Bowlsby's site. One of these diagrams should get you hooked up:
70~71 1.7L D-Jet Ignition Harness 72 1.7L D-Jet Ignition Harness |
Lo-Fi Version | Time is now: 19th May 2024 - 11:33 PM |
