oil temp gauge varies with electric load |
stecz |
May 26 2004, 07:27 AM
Member Group: Members Posts: 61 Joined: 20-February 04 From: Cedar Park, TX Member No.: 1,688 |
I have a semi-bizarre problem (although my Land Rover discovery did this as well)...
On my '73 914 2.0, the oil temp gauge read high, when the headlights are on. My car runs at about 210 degrees (I have a mechanical gauge on the dipstick), at that temp the oil temp gauge shows about 220. Which is fine, not sure which is more correct, but they are consistent. But, when I turn the headlights on, sometime the oil temp gauge goes up to close to 260. As soon as I turn the headlights off, it will return to indicate 220, so the oil isn't really increasing in temp. So, is that fixable? Is it likely to be a ground problem? Thoughts? |
Lo-Fi Version | Time is now: 18th May 2024 - 11:02 PM |
