Miss at Higher RPM? |
detoxcowboy |
May 14 2011, 10:36 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
1974 2.0 Stock except for Crane FireBall 3000 electronic ignition, all FI parts NOS or 2 years New.
I am getting a momentary small miss/skip at RPM's of approx. 3200 and 3800 randomly not always but usually when I am at a maintained constant speed. Any hints at what I should look at as a cause? It is slight but disconcering.. I have look most things over and there are no obvious tells.. Also another issue of RPM at idle dropping more than usual when headlights are on? a hint or possible seperate issue? New plugs and wires, fuel filter, air filter, oil, oil filter, trans oil.. and CHT Recent fix/ replced seals of vaccum leaks at the injectors.. Also reset timming and mixture ect.. |
914 shifter |
May 15 2011, 06:23 AM
airhead Group: Members Posts: 266 Joined: 28-August 10 From: ny/nj Member No.: 12,111 Region Association: North East States |
clean/lube distributor components. trigger points (IMG:style_emoticons/default/unsure.gif)
Lo-Fi Version | Time is now: 14th May 2024 - 08:14 PM |
