Thermostat and Heater flaps.. How important? |
Bill Meyer |
May 16 2011, 11:57 AM
Newbie Group: Members Posts: 44 Joined: 11-October 07 From: Prairie Village, KS Member No.: 8,210 |
In looking at this system my concern is growing that if the thermostat isn't working properly sometime in the future, I won't really know it and could cause the engine to start running hot. Wouldn't it be safter to just disconnect it? The car is mostly summer driven only and might see a few cold morning starts per year. Do these do anything other than aid quick warmup?
Thanks for any suggestions! Bill |
Rand |
May 16 2011, 12:10 PM
Aiding quick warmup is exactly what they do. It's better for your engine to warm up quickly. That being said I ran without a thermostat for years.
If the thermostat fails, it defaults to full cooling, so you don't have to worry about that. Disconnecting it would only prevent it from warming up quicker if the thermostat is good. If it fails it doesn't matter. |
nathansnathan |
May 16 2011, 12:17 PM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
Aiding quick warmup is exactly what they do. It's better for your engine to warm up quickly. That being said I ran without a thermostat for years. If the thermostat fails, it defaults to full cooling, so you don't have to worry about that. (IMG:style_emoticons/default/agree.gif) If the thermostat fails, you'll probably notice your oil becoming white and frothy from it not getting warm enough - it takes awhile for it to get to temperature without it and the blowby not getting a chance to burn off will cause that. Not having the flaps would be very bad, the one on the 3-4 side especially as it directs air to the oil cooler. Without that one the engine may get very hot once it does warm up. |
May 16 2011, 12:45 PM
Resident German Group: Admin Posts: 41,635 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
type47 |
May 16 2011, 12:56 PM
If you're worrying about type IV thermostats being NLA, it's possible to get a type I thermostat modified for type IV. Slightly different characteristics, but it will be a working thermostat.
enderw88 |
May 16 2011, 02:23 PM
Newbie Group: Members Posts: 35 Joined: 20-April 11 From: Tucson, AZ Member No.: 12,960 Region Association: Southwest Region |
Aiding quick warmup is exactly what they do. When an engine cools after running (this is general for all ICE, not just air-cooled engines) moisture will condense inside the engine and mix with the oil (remember that water is a combustion product). Getting the engine oil up to temperature quickly boils the water out. This is why doing many cold starts and never letting the engine come up to temperature is so bad on an engine. |
May 16 2011, 02:32 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The flaps inside the fan shroud are ABSOLUTELY CRITICAL and should never ever ever be left out of a street 914 motor. If you leave out the one on the right side in particular, air will not be forced down through the stock oil cooler and you will have problems.
--DD |
Bill Meyer |
May 16 2011, 03:30 PM
Thanks all, just what I was looking for. I had no intention of leaving the flaps out, just disconnecting the thermostat, which I won't do now after the above advice. I was just concerned it would fail in the closed mode, but I see what you're saying, it will loose it's suction or whatever and fail in the expanded state.
All good, hooked up it stays!! Thanks |
Lo-Fi Version | Time is now: 13th May 2024 - 02:54 PM |
