Plug wires |
Plug wires |
Bullet |
May 30 2004, 06:43 PM
Member Group: Members Posts: 116 Joined: 16-April 04 From: Newberg, OR Member No.: 1,940 |
I drove my 914 for the first time this afternoon (IMG:style_emoticons/default/smilie_pokal.gif) Only went 2 blocks and back. still doesnt run perfect yet. But i did finally Drive it. It seems to studder a little bit then it picks up fine and goes. I have replaced every injector, every componet of the ignition system exect for the plugwires. and all vaccum hoses are new and belived to be routed correctly. So I kinda suspect the wires to have high internal resisatnce. Does any one know the Specs for resistance on the Plug wires? Any help would be greatly apreciated.
URY914 |
May 30 2004, 08:03 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,389 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Old wires will also short out to the sheetmetal if they are just laying on the metal. Use some of those stand off brackets and the plastic wire holders.
Paul |
Lo-Fi Version | Time is now: 5th May 2024 - 02:10 AM |
