Bay Area: ***FS porsche 914 parts collection*** (central valley) $ |
914World |
May 24 2011, 12:28 PM
Member #1 Group: Members Posts: 130,681 Joined: 23-December 02 From: World Wide Web Member No.: 1 Region Association: None |
GLASS
1] Rear window {uninstalled excellent tinted} $90 shipped 1] Rear window (clear)$70 shipped 1] pass glass O.E.M. factory tint $40 shipped 1] driver wing glass O.E.M. factory tint $25 shipped 1] windshield (I will get out of attic to check details soon) LIGHTING & ELECTRICAL 1] set of very nice hella O.E. U.S. spec. tail light lens w/buckets and special attaching nuts $145 shipped 1] front euro turn signal light conversion kit (instructions, bulb sockets, dividers, etc. . .) everything needed to convert to euro but the lens $20 shipped 1] front lens w/ (2) seals $20 shipped 1] very nice "Porsche" reflective tail light section $165 shipped 1] set of chromed driving light grills, fins 100%, chrome shot $60 shipped 1] side marker light base $15 shipped 1] electric trunck release solenoid used with or w/out above reflector $50 shipped 1] 1972 d-jet relay board $30 shipped 1] fuel sending unit w/misc. attaching hardware $75 shipped 1] cut alt harness (good 4 alt plug body or pigtail) $15 shipped DRIVETRAIN 1] O.E. steelie beauty ring $30 shipped 12] unobtainium "Dan Gurney/western rim" shouldered lug bolts $30 shipped 1] set of stub axles with couple extra incomplete c.v. misc. axles & joints/parts $30 + shipping 1] set of complete used axels (ea. Has stub axle, axle, inner& outer joint good boots) $75 + shipping 4] brand new in wrapping, c.v. joint gasket seals, hard to find when you need them, all 4 $30 shipped 1] set of 911 trans sport mounts $50 shipped 2] main e-brake brake cables very nice condition $ 75 shipped ENGINE 1] Header w/ glass pack -after heat exchangers 2] unused 96mm "rimco bored/honed" Mahle cylinders light fin damage $75 each shipped 1] complete engine set of 1.7rockers for swivel conversion (no swivels or machining) $80 shippe 4] 1.7 high compression "euro" pistons and wrist pins $95 shipped 4] 96mm flat top pistons, pins and rings w/ rings $85 shipped 4] 1.7 yellow injectors & hold downs $50 shipped 1] j-tube $25 shipped 1] set of decent j-tube tin seals $20 shipped 1] 2 new cork, 1 rubber type valve cover gaskets, misc. engine gaskets, etc. . . $25 1] 1972 d-jet relay board $30 shipped 1] good used starter $65 shipped 1] huge bundle of misc. Nice o.e. braided hoses $25 shipped 1] ribbed/insulated heat tube $20 shipped 1] 2.0 throttle body w/ tps $ 75 shipped 1] 2.0 rubber throttle body to air cleaner sealing piece w/ clamp $25 shipped 1] NON sending unit oil cover and screen $20 shipped 1] cut alt harness (good 4 alt plug body or pigtail) $15 shipped 1] oil cap $10 shipped 1] rear brake caliper $25 shipped 2] good used oil pumps $30 each shipped shipped or $50 both shipped 1] evaporative canister with securing hardware $30 shipped INTERIOR 1] set of "butt breathing" fabric seat inserts, both w/ good sensors {worn material} great to temporary swap in for hot sweaty days or long drives $65 shipped 1] set of used crown vic power lock solenoids $30 shipped shipped 1] H/D power lock solenoid new $25 shipped1] Custom steel/vinyl covered 6 gauge panel w/lights and rocker switch area and misc. parts . . . unfinished project. . . $35 shipped shipped 1] about 20 ft. of special twisted CHT wire (I'll measure soon) $25 shipped shipped 1] used turn signal switch (no harness)$15 shipped shipped 1] Custom vinyl covered steel 6 gauge console face panel, unfinished project. Set up for rocker switches and multiple lighting, comes with misc. add your gauge selection and finish $50 shipped 1] O.E. walnut shift knob typical lens cracking but not too bad $30 shipped EXTERIOR 1] targa top w/ non opening sun roof. Great topless compromise for cool sunny days $75 + shipping 1] unused/brand new, trunk gas strut kit, will add a set of used bolt on struts if wanted $75 shipped 1] fuel sending unit w/ extra ring & mounting hardware misc. $75 shipped 1] engine trunk lid complete w/ grill solid west coast part $75 + shipping http://www.youtube.com/watch?v=2FM1Fnzyv8I
Lo-Fi Version | Time is now: 19th May 2024 - 07:58 PM |
