Another 914 won't start |
mrgjones |
May 24 2011, 11:07 PM
Member Group: Members Posts: 91 Joined: 23-November 09 From: Monterey Member No.: 11,062 Region Association: Northern California |
1975 2.0. No spark coming from the coil. Found what I think is the lead coming from the relay panel but no still no joy. What's supposed to be hooked up to the coil? Thanks for your time.
Tom |
May 25 2011, 01:23 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
You need switched 12 volts ( not sure of the color) to positive side of coil, a black purple(tach) and a green (distributor) to the negative side of coil.
Tom |
TheCabinetmaker |
May 25 2011, 06:35 AM
Black wire coming from the same part of the harness as the bl/pur, and green. The black wire goes to the coil.
mrgjones |
May 25 2011, 08:40 AM
Alright, I'll check that out. I remember seeing a diagram of the relay board but can't seem to find it again. Anybody? Thanks again. Vsg914 I just noticed your member number. That's quite auspicious in these end times. (IMG:style_emoticons/default/devil.gif)
Tom |
May 25 2011, 10:23 AM
Here is a thread that has a relar board dia. Post #17
http://www.914world.com/bbs2/index.php?sho...;hl=relay+board Tom |
mrgjones |
May 25 2011, 01:54 PM
Thanks Tom. That should help quite a bit.
TheCabinetmaker |
May 26 2011, 06:16 AM
Alright, I'll check that out. I remember seeing a diagram of the relay board but can't seem to find it again. Anybody? Thanks again. Vsg914 I just noticed your member number. That's quite auspicious in these end times. (IMG:style_emoticons/default/devil.gif) Yep, and I've been known to live up to that moniker too!!! (IMG:style_emoticons/default/happy11.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 10:51 AM |
