Wire Harness question, Brown/White near brake reservoir |
Kansas 914 |
May 27 2011, 10:35 AM
I laid my wiring harness back in the car last weekend and have a question about the brown and brown/white white that leaves the main wiring harness just after the firewall in the front trunk.
What does it terminate to? It continues down to the brake master cylinder pressure fail switch. I know what to do with it there - but what does it attach to up top? I am working on a early '72 model year. Thanks in advance! |
May 27 2011, 10:54 AM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I laid my wiring harness back in the car last weekend and have a question about the brown and brown/white white that leaves the main wiring harness just after the firewall in the front trunk. What does it terminate to? It continues down to the brake master cylinder pressure fail switch. I know what to do with it there - but what does it attach to up top? I am working on a early '72 model year. EDIT: Bollocks. I don't know what i'm talking about ... (IMG:style_emoticons/default/idea.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.pelicanparts.com-179-1306515265.1.jpg) |
Kansas 914 |
May 27 2011, 11:02 AM
Kansas 914 |
May 27 2011, 11:11 AM
Hmmm - 34 is handbrake contact - still confused.
May 27 2011, 11:12 AM
Lemme go look.
From what I recall, the old switch on the master had two prongs...the replacement has one prong. Give me a minute. Rich |
Kansas 914 |
May 27 2011, 11:15 AM
Lemme go look. From what I recall, the old switch on the master had two prongs...the replacement has one prong. Give me a minute. Rich Rich, This wire continues down to the MC location through the body with a grommett and then to the wires with the boot. The wires in question are between the MC and the firewall entrance. |
May 27 2011, 11:17 AM
The way its hooked up now is right.
I have one wire not doing anything due to the new sensor. RIch |
Kansas 914 |
May 27 2011, 11:27 AM
bdstone914 |
May 27 2011, 12:00 PM
bdstone914 Group: Members Posts: 4,517 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
What angle is that picture at? I believe the grommet in that picture is one I was trying to identify in my grommet thread.
Kansas 914 |
May 27 2011, 12:06 PM
May 27 2011, 12:26 PM
lemme go look at the breakout where you show it.
rich |
Valy |
May 27 2011, 12:30 PM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
1. Can you double-check the colors? From the picture it seems that none of the wires is white.
2. Are you sure you routed the wires the right way? It looks like the buzzer and door open switch would connect to that white and brown wires but that's located under the dash. |
May 27 2011, 12:31 PM
not much help here.
71 does not have that breakout in the harness. early 72 has the breakout but its blowing in the wind...not plugged into anything. saying that...my fresh air blower on the 72 has never worked... Rich |
914Mike |
May 27 2011, 12:39 PM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
I laid my wiring harness back in the car last weekend and have a question about the brown and brown/white white that leaves the main wiring harness just after the firewall in the front trunk. What does it terminate to? It continues down to the brake master cylinder pressure fail switch. I know what to do with it there - but what does it attach to up top? I am working on a early '72 model year. Thanks in advance! I've seen brake fluid reservoir caps that had two terminals on them, maybe your harness was modified to take one of those. It's the right length, and wired to the correct wires... |
May 27 2011, 01:00 PM
This is in the front trunk (barely). Hmmm, that does look odd there. Ignore my previous post, i was thinking of a different wire. This main harness does not have that brake-out connection: (IMG:style_emoticons/default/idea.gif) (IMG:http://www.914world.com/bbs2/uploads/post-2-1088111947.jpg) |
May 27 2011, 01:02 PM
That is funny.
I love how everything looks easy enough to find....till you get to the pile of wires marked "gauge cluster" Rich |
rick 918-S |
May 27 2011, 01:07 PM
Hey nice rack! -Celette Group: Members Posts: 20,449 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I checked a 72,73,and 74. The 73 and 74 did not have the upper wiring. My 72 ( (IMG:style_emoticons/default/alien_2.gif) ) has the upper wires but they are not plugged into anything. It reminds me of my BMW 2002. The brake cap is the same style but has a float attached to the under side. Two wires plugged into the cap and activated a brake light warning if the fluid level was low. I don't think you need to worry about those Mike.
The lower wires are for the brake light switch on the master cylinder. If the wires don't reach the switch location check to see if you have it run correctly on the other side of the firewall. You may have a snag caausing the wires to be too short. |
Kansas 914 |
May 27 2011, 01:22 PM
QUOTE I've seen brake fluid reservoir caps that had two terminals on them, maybe your harness was modified to take one of those. It's the right length, and wired to the correct wires... I have owned this car since 1978 - unmolested - I'm the second owner. This a factory wiring harness - no mods. Maybe the factory was going to use the fluid reservoir with a pressure switch cap (perfect length) buy chose not to later? (IMG:style_emoticons/default/confused24.gif) Odd to leave the wires there unterminated - slight potential for a ground. Wierd........ |
May 27 2011, 01:28 PM
I've seen brake fluid reservoir caps that had two terminals on them, maybe your harness was modified to take one of those. It's the right length, and wired to the correct wires... I have owned this car since 1978 - unmolested - I'm the second owner. This a factory wiring harness - no mods. Maybe the factory was going to use the fluid reservoir with a pressure switch cap (perfect length) buy chose not to later? (IMG:style_emoticons/default/confused24.gif) Odd to leave the wires there unterminated - slight potential for a ground. Wierd........ I looked at Abel's wrecked 73 and I dont see a break out...it may be under the tank, but I cant see it there. Cap was from a box of parts...so that wont be OEM... Rich |
Kansas 914 |
May 27 2011, 01:37 PM
Lo-Fi Version | Time is now: 10th May 2024 - 03:21 PM |
