Early rain tray - pre '74, Just to get it documented here |
Pat Garvey |
Jun 3 2011, 07:20 PM
This has been my Quixote for the last several years.
There were two 914-4 rain trays. The early one (pictured) was used from the beginning to sometime in early 73, when it was replaced with a much better form. I've been attemptimg to find the partno for this long discontinued part, but have had no success. Would have posted it elsewhere. This early form of rain tray was/is flat-bottomed and supported by L-shaped metal trusses riveted to the engine lid (underside). It's different from the later form, which had molded in horizontal support structures. Most, if not all of the early trays suffered from from vibration cracking at one or more of the mounting points - probably why it was replaced. The pic is of my original 72 tray. Note that it has a major split at one of the mounting points. I've bought 5 now & only 2 are better. Niether is good enough for my 914 & I've sent a "mule" to mikey914 for consideration. Wish I new the partno though. Pat Attached image(s) |
Pat Garvey |
Jun 8 2011, 07:02 PM
So........no one knows?
Or, no one cares? Interesting, because there were somewhere around 40K 914's produced with this rain tray. Guess all of you in this tray have perfect ones, eh? Or, could it be that you're 914 was converted to the later style (probably). So, how come, with so many gurus out there, that this seems to be a mystery? Huh? Did they not change the original partno when the tray changed, and merely supercede it with the new? |
nathansnathan |
Jun 8 2011, 07:50 PM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
I've got the early rain tray in my 72. I've got the 2 outer metal brackets still attached, middle one is missing.
I wonder about plastic welding the cracks, got one on each mounting hole, one at the big 'hump' and one at 1 of the holes between. Also it's deformed on that same side, curved out at the middle. I was thinking about reforming it with a heat gun. It looks like the bird has 2 versions listed, maybe the early and late, this from a google result, same oem part number but there is a different store part number for each. http://pp.paulheery.com/carson/dillard.pl?...0512%20189%2010 |
Jaymann |
Jun 9 2011, 07:34 AM
Member Group: Members Posts: 140 Joined: 18-August 09 From: Drexel hill pa Member No.: 10,692 Region Association: None |
Hey Pat:Thats the same tray, I have in my car.I have a 1975 1.8 4, it was built in 1974.Sorry, but I dont know a part #.Jason
Jun 9 2011, 11:19 AM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
If the one that came off my red car is early and good, it's all yours. Ask Scotty B to take a look.
Pat Garvey |
Jun 9 2011, 06:49 PM
Nemo914 |
Jun 20 2011, 08:26 AM
Member Group: Members Posts: 76 Joined: 11-July 03 From: Cape Cod, MA Member No.: 902 |
Hello all--been off the site for a long time, but was working on fixing some cracks in my early style raintray, and this post was perfect timing! I was thinking about trying to use a product called Plastex to repair cracks and even "re-mold" two of the mounting points. Has anyone used this product before? What other "repair" options are there for plastic? My rain tray is straight and in excellent condition other than the left and right mounting points (that face the rear side of the engine lid) are cracked off. Thanks! Nemo
nathansnathan |
Jun 21 2011, 11:28 AM
Hello all--been off the site for a long time, but was working on fixing some cracks in my early style raintray, and this post was perfect timing! I was thinking about trying to use a product called Plastex to repair cracks and even "re-mold" two of the mounting points. Has anyone used this product before? What other "repair" options are there for plastic? My rain tray is straight and in excellent condition other than the left and right mounting points (that face the rear side of the engine lid) are cracked off. Thanks! Nemo I was reading about Plastex. It's supposed to be the kit has 2 'colors' of the stuff - 1 is for areas that experience high heat, which the rain tray would require. Reviews of the stuff will say that the high heat 'color' is quite brittle when it sets so probably it would crack through again. From what I gather, plastic welding would be the best option, not sure if it is high or medium density polyethylene that it is made out of (mcmaster-carr sells 2 types of polyethylene filler rod). Best bet would be to use part of another rain tray for the filler rod. |
Pat Garvey |
Jun 21 2011, 07:44 PM
Two years ago I cut several pieces from a badly deformed tray, run them through a small food processor until they were powder. Using a very high temp heater/blower, I sprikled the dust into a crack. Then continued heating until it melted into the crack. Turned the heat lower to "cool" it down, then lower again for about 5 minutes. The crack literally disappered and, though a scrutinous eye could find the repair, I was happy with it.
Set the tray in a corner to cool (inside temp was about 85), poured myself a celebritory drink and heard a large "crack". The tray had spewed out all the melted dust and remained as prior! These things are made of some secret compound that will not accept repairs! Hope Mikey comes up with something. Pat |
Mikey914 |
Jul 3 2011, 11:18 AM
The rubber man Group: Members Posts: 12,652 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have spoken to Pat about this and yes I have this project in the cue, onlt because of the size the tooling will be a significant investment. I have to get some more tooling money back on a few projects I've got going and one more big project to get ironed out before I can make this happen, but hopefully we are not too far away.
-Mark PS I plan on doing this either way, but may start a who needs thread to see if the demand would pencil out to pull some cash out of savings to make this happen sooner. |
Pat Garvey |
Jul 3 2011, 07:14 PM
I have spoken to Pat about this and yes I have this project in the cue, onlt because of the size the tooling will be a significant investment. I have to get some more tooling money back on a few projects I've got going and one more big project to get ironed out before I can make this happen, but hopefully we are not too far away. -Mark PS I plan on doing this either way, but may start a who needs thread to see if the demand would pencil out to pull some cash out of savings to make this happen sooner. Mark, You are my hero! Pat PS to all '69-early 73 914 owners. If you don't have the flat bottomed rain tray (no convoluted bracing) for your 914's it is incorrect! This is our chance to have them reproduced! Tell Mark that you're in when he gets to it! |
1970 Neun vierzehn |
Jul 7 2011, 08:58 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
Count me in for one.
Paul |
Pat Garvey |
Jul 8 2011, 06:48 PM
(IMG:style_emoticons/default/icon_bump.gif) C'mon, there have to be more early four owners with the wrong rain trays. Speak up! (IMG:style_emoticons/default/icon_bump.gif)
Towarish |
Jul 10 2011, 02:22 AM
Newbie Group: Members Posts: 49 Joined: 11-February 08 From: Germany Member No.: 8,699 Region Association: None |
So........no one knows? Or, no one cares? Interesting, because there were somewhere around 40K 914's produced with this rain tray. Guess all of you in this tray have perfect ones, eh? Or, could it be that you're 914 was converted to the later style (probably). So, how come, with so many gurus out there, that this seems to be a mystery? Huh? Did they not change the original partno when the tray changed, and merely supercede it with the new? Exactly ! According to the partslist of 1/73 the spare# is 914.512.189.10. ( Thanks to Klaus Straub) When they changed the shape of the raintray,they kept the number and just gave you the new part. This happens all the time and is really annoying. If you order a door ,front lock bar, bumper or whatever,you always got/get the last model without knowing before,what you get. BTW :I was always wondering,why they needed a raintray just for th -4 and not -6 ? |
Pat Garvey |
Jul 11 2011, 06:14 PM
So........no one knows? Or, no one cares? Interesting, because there were somewhere around 40K 914's produced with this rain tray. Guess all of you in this tray have perfect ones, eh? Or, could it be that you're 914 was converted to the later style (probably). So, how come, with so many gurus out there, that this seems to be a mystery? Huh? Did they not change the original partno when the tray changed, and merely supercede it with the new? Exactly ! According to the partslist of 1/73 the spare# is 914.512.189.10. ( Thanks to Klaus Straub) When they changed the shape of the raintray,they kept the number and just gave you the new part. This happens all the time and is really annoying. If you order a door ,front lock bar, bumper or whatever,you always got/get the last model without knowing before,what you get. BTW :I was always wondering,why they needed a raintray just for th -4 and not -6 ? Due to the high clearance required by the six air cleaner & carb setup, there was no room left for a rain tray. In hindsight, they should have figured something out. Then again, they probably needed the addition airflow for the six motor. Pat |
monkeyboy |
Jul 15 2011, 10:18 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
I'd be in for one.
Rob914 |
Jul 15 2011, 08:50 PM
Member Group: Members Posts: 113 Joined: 8-April 03 From: Lake Villa, IL Member No.: 541 Region Association: None |
I am in for one.
Rob |
Jul 15 2011, 11:46 PM
So now we have 4 (four!) early 914s that would get the first design rain tray. Surely there must be more than four MY '70-'72s that would be enhanced by having a correct and unbroken rain tray beneath their engine lid.
nathansnathan |
Jul 16 2011, 12:54 AM
I'd be in, too!
Pat Garvey |
Jul 23 2011, 07:30 PM
Hope Mark is tuned into this thread. We now have five. Tooling costs should be getting close to making this part a sale - hopefully!
Lo-Fi Version | Time is now: 4th May 2024 - 11:31 PM |
