Exhaust stud, coming loose |
Elliot Cannon |
Jun 9 2011, 12:37 PM
I thought it was the nut that was coming loose. It turns out the stud will not stay tight resulting in a leak. What can I do to keep the stud in tight? Would it be too hot for locktight? What are my options other than tightening it down till it breaks. (IMG:style_emoticons/default/confused24.gif)
Attached thumbnail(s) |
Mike Bellis |
Jun 9 2011, 01:19 PM
Put a little JB Weld on the threads. The heat will not make the JB very strong but it should hold it in until you need to remove it.
914Mike |
Jun 9 2011, 01:37 PM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
I thought it was the nut that was coming loose. It turns out the stud will not stay tight resulting in a leak. What can I do to keep the stud in tight? Would it be too hot for locktight? What are my options other than tightening it down till it breaks. (IMG:style_emoticons/default/confused24.gif) Is that an aftermarket lock nut? If so, that's your problem. Get the right nut on there and the stud should stay in... |
Bartlett 914 |
Jun 9 2011, 01:38 PM
Advanced Member Group: Members Posts: 2,214 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
HAM Inc |
Jun 9 2011, 01:40 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
JB weld will not work, and he is not at a point of desperation. Since he has a 8mm stud coming out he can go up to a 10x1.5-8x1.25 step stud.
A Time-Sert is also an option. If he tries the JBWeld it will fail and make the workable repairs listed above much more problematic. Good luck! |
Chris Pincetich |
This happened to me on 3-4 of the studs. I bought new ones then cranked em in there real tight. I was way too nervous to put lots of torque on the old studs. Now I have some new, some old studs, with spares to replace the old ones when they come loose. Eventually, every part on my 914 seems to come loose and need attention (IMG:style_emoticons/default/beerchug.gif)
I will be back under there replacing the poor "seal" I made on the stubs to my header this weekend and will check on my fix(es) while I am down there. |
Cap'n Krusty |
Jun 9 2011, 01:51 PM
I thought it was the nut that was coming loose. It turns out the stud will not stay tight resulting in a leak. What can I do to keep the stud in tight? Would it be too hot for locktight? What are my options other than tightening it down till it breaks. (IMG:style_emoticons/default/confused24.gif) What engine? The Cap'n |
Elliot Cannon |
Jun 9 2011, 01:58 PM
I thought it was the nut that was coming loose. It turns out the stud will not stay tight resulting in a leak. What can I do to keep the stud in tight? Would it be too hot for locktight? What are my options other than tightening it down till it breaks. (IMG:style_emoticons/default/confused24.gif) What engine? The Cap'n Type IV |
Cap'n Krusty |
Jun 9 2011, 03:27 PM
I thought it was the nut that was coming loose. It turns out the stud will not stay tight resulting in a leak. What can I do to keep the stud in tight? Would it be too hot for locktight? What are my options other than tightening it down till it breaks. (IMG:style_emoticons/default/confused24.gif) What engine? The Cap'n Type IV Oh. One of the common issues here is the integrity of the boss on the head. Exhaust port cracks can intrude into the boss, or they can otherwise weaken the material in that area. I could attempt to install an insert for you, but it has been my experience that you have about a 50/50 chance of saving it. Used to be an easy fix, back when all the heads had a few miles on 'em. Now, not so much. There is NO easy magic fix. None. The Cap'n |
HAM Inc |
Jun 9 2011, 03:57 PM
The Cap'n may be right. If the stud pulled out of one of the inner bosses (closest to the center of the engine) then it is entirely possible that the stud pulled out because of a crack. They radiate from under the ex valve seat out to the stud boss. It's pretty obvious when that is the case as you can get a good look at once the exhaust is off. If that is the case it's time for the heads to be re-worked, or tossed.
If it pulled out of one of the outer bosses the likelyhood of a crack precipitating the failure is extremely remote. |
Elliot Cannon |
Jun 9 2011, 05:43 PM
The stud didn't exactly "pull out". It was just loose. I tightened it about a week ago and it came loose again. I went to NAPA and found an M8, 1.25 X 50 stud, put it in, tightened it down and now we'll see how long this one lasts. Thanks for all the help.
Cheers, Elliot |
cary |
Jun 10 2011, 08:48 AM
My .02C.
First get the right exhaust nuts. That looks like a lock nut. And its rusted on. On the new nuts use copper based anti-seize. That way they will come off the right way. Nut first, not stud and all. I like you just went to NAPA and put in new studs. They've been holding fine in both 914 engines and the 911 engine. If the threads are trashed you'll have to do inserts. |
Elliot Cannon |
Jun 10 2011, 10:18 AM
My .02C. First get the right exhaust nuts. That looks like a lock nut. And its rusted on. On the new nuts use copper based anti-seize. That way they will come off the right way. Nut first, not stud and all. I like you just went to NAPA and put in new studs. They've been holding fine in both 914 engines and the 911 engine. If the threads are trashed you'll have to do inserts. That IS a copper exhaust nut. It wasn't rusted on. It came right off the stud. |
Cap'n Krusty |
Jun 10 2011, 10:41 AM
My .02C. First get the right exhaust nuts. That looks like a lock nut. And its rusted on. On the new nuts use copper based anti-seize. That way they will come off the right way. Nut first, not stud and all. I like you just went to NAPA and put in new studs. They've been holding fine in both 914 engines and the 911 engine. If the threads are trashed you'll have to do inserts. That IS a copper exhaust nut. It wasn't rusted on. It came right off the stud. First of all, those are NOT "copper exhaust nuts" They're "copper PLATED steel self locking nuts". I don't understand why this bogus belief won't go away! Locking nuts have no place on exhaust studs on a Porsche air cooled engine. They were readily available when the cars were built, but the engineers at Porsche and VW chost not to use them. I don't either, having seen too many problems related to their use in this application. They're fine on water cooled applications, and both VW and Porsche used them in those apps. The Cap'n |
cary |
Jun 10 2011, 01:31 PM
This is the type I use.
http://www.pelicanparts.com/cgi-bin/smart/...76%29%2C%20Each |
Cap'n Krusty |
Jun 10 2011, 01:55 PM
Just because Pelican sells a BMW part (that's what they call it in the catalog) that they say fits a 914 doesn't make it right for your application. I repeat, Porsche and VW chose not to use self locking nuts on the exhaust systems of their air cooled cars, notwithstanding the availability of such parts. You don't NEED locking nuts on the exhaust. People use split lock washers there, too, despite the fact that it's a widely accepted fact in the industry that they have no place in the exhaust system. Go figure. That said, you're free to put anything you want on your car, right or wrong. The Cap'n |
HAM Inc |
QUOTE Locking nuts have no place on exhaust studs on a Porsche air cooled engine. They were readily available when the cars were built, but the engineers at Porsche and VW chost not to use them. I don't either, having seen too many problems related to their use in this application. They're fine on water cooled applications, and both VW and Porsche used them in those apps. The Cap'n I'll second that! I hate the damn things and also feel that they have no place on these engines. They cause way more trouble than they prevent. On my race heads I use the internal wrenching 911 ex nuts. |
HAM Inc |
Jun 10 2011, 02:02 PM
And I should also add that it is not possible to use to much anti-seize down there. I slather it on the studs before I screw them in the heads and slather it all over the studs and the nuts. I prefer the copper based stuff as it handles the heat better than the silver permatex stuff.
I know NAPA sells copper based and I imagine that some other FLAPS do to. |
76-914 |
Jun 10 2011, 02:24 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
OK, Cap't and Ham. You both mention that those nuts cause problems but would you mind enlightening us dumbasses just what those problems are? (IMG:style_emoticons/default/confused24.gif) And El Liot, mine did the same thing last year before RRC. I Helicoiled mine and then made the mistake of posting it. Turns out the crowds favorite is a timecert or something similar to that.
HAM Inc |
Jun 10 2011, 02:39 PM
Heli-Coils are fine.
The clinch nuts drag the stud back out when they are removed. That usually means that aluminum threads are drawn out. Might as well just use a bolt. I have also had MANY heads that landed in my shop when folks were installing their ex with new clinch nuts on old studs and the studs broke before the nuts got very far up the threads. Now that is not to say that the studs weren't old and flaky to begin with, because they were. But I have also seen them damage the threads on new studs. Based on first hand experience I am not a fan. |
Lo-Fi Version | Time is now: 28th April 2024 - 11:00 PM |
