Information needed, Can two different engine case halves be put together? |
PBC914 |
Jun 12 2011, 08:41 AM
Member Group: Members Posts: 192 Joined: 30-December 10 From: Minneapolis Member No.: 12,545 Region Association: Upper MidWest |
Facing an issue with a cracked top case at the seam, the other side is perfect. Instead of replacing both, I wanted to find out if anyone has tried putting two different case halves together (same engine size). Thanks in advance for your responses.
jmill |
Jun 12 2011, 08:51 AM
Not without machine work. You'll need a line bore for sure. If you look at the money you'll spend on that, it might be cheaper to get a new case.
underthetire |
Jun 12 2011, 11:25 AM
I would think you would need to have the barrel registers machined as well to keep them the same. Don't think it's worth it unless your doing a full machine job on the case.
McMark |
Jun 12 2011, 12:41 PM
No. With the usual caveat: you can do anything with money.
Lo-Fi Version | Time is now: 17th May 2024 - 06:20 AM |
