Stupid chassis tricks, am i crazy (in this case) |
mskala |
Apr 19 2003, 09:34 PM
Okay, new problem, trying to get my windows to line up reasonably
close to the 3 sides of the car. Passenger side not too bad, down about 3/16" in the back when adjusted as much as I can. BUT, the driver's side has slowly been beating away the seal hitting the triangle, and at the top front corner. Now, this car is far from a sagger, and I only have one theory. That is that maybe the windshield frame has been pushed down (more on driver's side). These things aren't very strong, are they? There's been times where I just grab the front and the targa bar and jump in, am I pushing it down myself? If it is not right, can it be pushed up a bit to fix this problem? Any help would be appreciated. (IMG:style_emoticons/default/pray.gif) Mark S. '70 914-6 |
Apr 19 2003, 10:26 PM
Resident German Group: Admin Posts: 41,649 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
the windshield frame flexes very easily.
but usually, it moves back into the original position. you can measure the distance from the floor on the edges and see if there's a difference on either side. make sure you have both doors wide open (or removed) when measuring. also, the door height can be adjusted. maybe your door just needs to be a bit lower. the door mounts slide up/down after you losen the bolts. the same goes for the lock plate in the back. you can move the whole door up/down. just my 2 cents ... Andy |
mskala |
Apr 20 2003, 10:35 AM
Thanks Andy, I didn't know that the front nut plate could move around,
never been inside there before. So far, it doesn't look like enough adjustment, though. I am going to measure the frame, and also see really what happens when I take off some weight from the middle by jacking with a 2x4. Mark S. '70 914-6 |
rhodyguy |
Apr 20 2003, 11:39 AM
the manner in which the early window glass was held in place at the bottom left something to be desired. is the glass sitting true/tight in the rect metal piece that holds it. if the little guide rollers that sit on the pins on the vert metal strip on the front of the window have gone south that might contribute to the problem as well.
kevin |
Brad Roberts |
Apr 20 2003, 12:38 PM
Are you adjusting the chrome channel guide for the window (from the bottom of the door) ?? There is a lot of adjustment there.
B |
mskala |
Apr 20 2003, 01:53 PM
QUOTE(Brad Roberts @ Apr 20 2003, 01:38 PM) Are you adjusting the chrome channel guide for the window (from the bottom of the door) ?? There is a lot of adjustment there. B Yea I know about the normal adjustment there, but it really isn't solving it because that pivots in such a way that (if there was enough adjustment in my case) if the triangle glass lined up well, the top window edge would be down a huge amount. Also the chrome channel goes up too high. I measured the height at each side, and the left side is 1/8" lower. I see what people mean when they say it's not strong, if I have my straight edge ruler there I can move it that far with just my hand. I think I would have things under control if I could press the left side up. Mark S. '70 914-6 |
Brad Roberts |
Apr 20 2003, 01:58 PM
My favorite is when people waste a race cage pickup point by going to the windshield...LOL
Be very careful pressing on the winshield frame.. I would hate for you to break the windshield. I also do a measurement from the B pillar (targa bar) to the A pillar (windshield hoop) Find a common measurement place that you can use on both sides. The other thing we do (dont tell anybody) : Place a floorjack and a piece of wood with a bathroom towel over it and slowly lift the door (back near the end) The OE hinges are starting to sag.. and need some help *Up* B |
mskala |
Apr 20 2003, 02:51 PM
Not that I want the windshield to break, but my ace in the hole
is that the windshield has been delaminated at the corners since before I got the car. Crap aftermarket one I guess. Mark S.(IMG:http://members.rennlist.com/marks/build.gif) |
campbellcj |
Apr 20 2003, 11:18 PM
QUOTE(Brad Roberts @ Apr 20 2003, 11:58 AM) My favorite is when people waste a race cage pickup point by going to the windshield...LOL Ya know...I've been seeing some cars at various events with "gusseted" rollcages, i.e. welded continuously to the windshield pillars, door pillars etc. I always wondered if it was (a) legal and ((IMG:style_emoticons/default/cool.gif) worth doing or just "for show". |
Brad Roberts |
Apr 20 2003, 11:30 PM
If you want the windshield posts to be strong... gusset them. I'm personally not going to waste 2 points in the cage by going to the windshield. 911 guy's do it... dont know why..
Mark, What did you come up with ?? I pulled a door panel off of "Muellers6" and started farting around with adjusting the window/track. Its catching on the rubber on the A pillar. Andy notice this evening that the door may be mounted a little high. I'll drop it tomorrow. B |
Apr 21 2003, 04:16 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Its a dmn good thing you have Andy, the newly named 914 Guru by your side Brad,,,,,
:cursor: |
Apr 21 2003, 04:31 PM
QUOTE(r_towle @ Apr 21 2003, 02:16 PM) Its a dmn good thing you have Andy, the newly named 914 Guru by your side Brad,,,,, haha, "914 Guru" is the default setting for everyone who has 500+ posts and didn't fill in a custom member title. you only need 306 more posts and you will be a guru too! Andy |
mskala |
Apr 21 2003, 05:53 PM
Brad, I'm going slow. First try at pressing to 1/4" didn't do anything.
Came back. Going to 1/2" seemed to raise it a little. Doing some more now. Mark S. '70 914-6 |
Brad Roberts |
Apr 21 2003, 05:54 PM
Thanks Mark.
Keep us posted. This will make a good thread. B |
mskala |
Apr 21 2003, 05:59 PM
I thought I could have pictures but I found out today that
even though the ruler is very close to it, it's not close enough. Depending on the angle you look at it it's different. And my seal, which was in bad shape before, is destroyed so I really am now just wingin' it. Mark S. '70 914-6 |
Brad Roberts |
Apr 21 2003, 06:16 PM
I'll shoot some pics. I still have the door panel off and the seals are all new on this car.
B |
mskala |
Apr 21 2003, 08:50 PM
Alright, I guess I was on the right track. (IMG:style_emoticons/default/clap56.gif) At least I can't think of any
other way to accomplish what just happened. After lifting about 1/2", the thing moved up slightly. So I did it again, went up to about 5/8" and a few hours later (who knows if you have to wait) I put it down and it is between 1/8" and 3/16" higher. Before and after pics in this and next post. At that point, the door and window was easily adjustable to get ALL 3 sides good. The top followed the roof very accurately. No cracky. The thing made a few creaks most times I jacked it, but no problems. Here's the before pic with ruler Mark S. '70 914-6 Attached image(s) |
mskala |
Apr 21 2003, 08:53 PM
... and after
It seems the moral of the story is don't jump in the mofo like Dukes of Hazzard, and cancel the photosession of supermodels lying on the front (IMG:style_emoticons/default/tongue.gif) Mark S. Attached image(s) |
Brad Roberts |
Apr 21 2003, 09:18 PM
So.. you jacked the door up and adjusted accordingly.. or just jacked the door up ??
B |
mskala |
Apr 22 2003, 11:44 AM
I did move the door back up to the high position, but at least on
my car it moves a very small amount. I messed with the window adjustment, but it was clear that the PO saw that it was hard to get the window in the groove and had adjusted it all the way to the most force inward. Mark S. '70 914-6 |
Lo-Fi Version | Time is now: 20th May 2024 - 04:02 AM |
