ECU Application, Use of 71 on 73 914 |
edms914 |
Jun 12 2004, 08:31 AM
Newbie Group: Members Posts: 1 Joined: 1-June 04 From: Bellevue, Washington Member No.: 2,139 |
What would be the problem in using a 71 ECU on a 73 914. When comparing cable tterinals they match. Is the potential problem internal to the ECU? Ed M.
anthony |
Jun 12 2004, 08:44 AM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
If they are both 1.7L ECU then it should work. Consult Brad Ander's site:
http://members.rennlist.com/pbanders/DJetP...m#Compatibility |
pbanders |
Jun 12 2004, 09:28 AM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
Pretty much like Anthony said. The '73 2.0 uses a 1.7L ECU (0 280 000 037), in combination with different injectors, MPS, and a ballast resistor in series with the head temperature sensor to accomodate the difference in displacement.
Lo-Fi Version | Time is now: 8th June 2024 - 02:20 PM |
