Need advice on early 15X6 Fuchs, Problem for tire shops? |
thomasotten |
Jun 12 2004, 08:47 PM
Senior Member Group: Members Posts: 1,547 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
Do the 15X6 deep dish "early" 911 Fuchs wheels present a problem for tire shops? I have heard that some have problems mounting and dismounting tubless tires on them. Is this the case and is it a hassle to get tires mounted? Is anyone running tubless tires on them, and if so can I have a brand/size as a reference?
Thomas |
ArtechnikA |
Jun 13 2004, 06:22 AM
QUOTE(thomasotten @ Jun 12 2004, 06:47 PM) Do the 15X6 deep dish "early" 911 Fuchs wheels present a problem for tire shops? I have heard that some have problems mounting and dismounting tubless tires on them. Is this the case and is it a hassle to get tires mounted? Is anyone running tubless tires on them, and if so can I have a brand/size as a reference? shouldn't be a problem for a good, modern high-end tire shop with no-touch tools and a careful operator. i noticed a couple of small scratches after i had a set of tires dismounted at the local general-purpose garage (so much for the recommendations of co-workers ...) i doubt the guy had ever encountered wheels like those and had no concept of the issues or value... anyway - what was on the car was Yoko Avid T4's, 215-60. |
carr914 |
Jun 13 2004, 09:10 AM
Racer from Birth Group: Members Posts: 119,001 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
As long as you some research on the shop mounting the tires vs a shade tree mechanic, you should be okay. I've run Yokohama 205/50's. They are harder to mount, but with good mounting equipment it can be done.
Lo-Fi Version | Time is now: 8th June 2024 - 09:10 AM |
