RustyWa |
Working Member ![]() ![]() ![]() Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 ![]() |
So what is the size of the nut, on the tranny end, holding the wedge on?
I had two nuts "locked" together that came undone the other day, so I went looking for a nyloc nut instead, but couldn't find the correct size. |
pbanders |
Senior Member ![]() ![]() ![]() Group: Members Posts: 943 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 ![]() |
Don't know the particulars of it, offhand, but it's 11 mm, and you can get it in a nyloc from Lowe's hardware store's metric nut section.
Matt Romanowski |
Senior Member ![]() ![]() ![]() Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 ![]() |
I believe it's a M7.
Matt |
MXMARK |
Member ![]() ![]() Group: Members Posts: 205 Joined: 15-February 04 From: Riverside, Ca. the new (951) Member No.: 1,656 ![]() |
Are you asking thread size. I think it is 7mmx1mm pitch, 11mm nut on mine. I hope I am right. Mark
I forget. |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,339 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
(IMG:style_emoticons/default/agree.gif) with mark
RustyWa |
I'll check Lowes again.
7mm x 1.0 sounds about right, couldn't find that size at my primary stops. The 8mm was to big, 6mm was to small. So thought it might be std. and not metric. The existing nut fit on a 1/4"-28 bolt, but it was a little loose, and the nut ended up not fitting at all on the cable. Thanks |
john rogers |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 ![]() |
M7 is correct and they use 11mm wrenches. Make sure to use TWO nuts jammed together as a single nyloc type will slip loose due to the heat and vibration under there.
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Just use two 7mm nuts like the factory used as the single nylock with fall off. Ask me how I know that one..... Geoff |
MXMARK |
Last time I needed the nuts for this I got them from my local KTM motorcycle dealer. Yes locking the nuts together will not come out of adjustment until the cable dies. Thank you for bringing that up John. Thanks Mark
ss6 |
fun city... ![]() ![]() Group: Members Posts: 261 Joined: 2-February 03 From: Western Connecticut Member No.: 221 ![]() |
Strangely enough, I found my M7's at my local auto parts store. Detroit is about the only car supplier NOT using metric these days.
TheCabinetmaker |
QUOTE(ss6 @ Jun 13 2004, 03:25 PM) Detroit is about the only car supplier NOT using metric these days. Changed the tranni filter and fluid on my daughters intrepid yesterday. metric bolts on the pan. The cabinet industry is almost excluvisely metric these days. |
Lo-Fi Version | Time is now: 12th July 2025 - 07:04 AM |
