It's alive but water pump has a bad seal & leaks, If I can find one in stock I have a chance tommorow |
JRust |
Jun 18 2011, 06:09 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay so I have 3 wires not hooked up I am not sure about. One is a white wire, One green with red strip & one solid red coming off the coil side of things. I get nothing when I turn the key to start. No click or anything from the starter. I tried using a screwdriver to jumpr the starter. I only get sparks & nothing else from the starter. I am so damn close but I am missing something I bet is simple.
With this being a conversion the wiring is a screwy thing anyway. I appreciatte any things I can try (IMG:style_emoticons/default/smile.gif) Oh yeah this is for my buick 215 v8 |
Mike Bellis |
Jun 18 2011, 07:04 PM
There are two big red wires that usually connect to the battery. On a stock 914 you would see 4 red wires connected to the battery. Two of those go to the alternator, the other two to the dash. One runs to the ignition and the other to the fuse panel. In some installs the two big reds get hooked to the alternator. You would then need a wire from the alternator to the battery. You are missing one of these links. I think. I'm not sure how yours is wired. It looks like you still have a relay board.
McMark |
Jun 18 2011, 07:52 PM
If jumpering the starter doesn't work, the starter is dead, most likely.
The white wire is for the AAR, make sure that one is taped off well. The green/red wire is for the 'idiot light' or, more technically, oil pressure switch light. The red wire... (IMG:style_emoticons/default/confused24.gif) |
JRust |
Jun 18 2011, 08:45 PM
Is there a way to test a starter on the bench?
hot_shoe914 |
Jun 18 2011, 08:58 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Yup, send juice to it and see if it engages.
McMark |
Jun 18 2011, 09:17 PM
Jumper cables. Connect the + to the 8mm stud where the battery cable goes. Hook the - to the case of the starter. Then jumper the + to the spade terminal. Shoot a pic and I'll annotate it if I didn't explain that well.
JRust |
Jun 18 2011, 09:45 PM
No that makes perfect sense. Was just missing a step with the test part on one out of the car. I did get a try & some smoke out of my starter on the car. IT did not turn the motor over.
I am afraid my motor is locked up. (IMG:style_emoticons/default/sad.gif) Just from sitting. I put some Sea foam down the plug holes. Letting it sit & going to try to break things loose tommorow. Guess my luck working on 914's is holding out huh (IMG:style_emoticons/default/headbang.gif) |
rhodyguy |
Jun 18 2011, 10:06 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
jamie, if the engine was locked up you'd still hear the selonoid engaging. one large red wire from the battery and one smaller red to the post on the starter. yellow to the spade connector next to the stud. is the plug with green, brown and red wires plugged into the relay board in the engine compartment?
k |
JRust |
Jun 18 2011, 11:00 PM
Yeah I hooked up to the 2 thicker red wires to the positive battery terminal. Starter still doesn't work with the key. With the key on & jumping the terminal the selonoid did come on but them smoke. Starter definately isn't turning the motor. Tried to move the car in gear to break it free but no luck. Going to work on it a little more tommorow. See if I can get it to break loose. I put some see foam in each spark plug hole. Letting it soak tonight. I'll put some more in tommorow before church. When I get back I will try to get it to break free. This motor was running great when I put it on the stand. It had oil in it too (IMG:style_emoticons/default/dry.gif) . Such is life
JRust |
Jun 19 2011, 09:26 AM
What do you guys recommend is the best way to break it free. Just jack up one side of the car & get one wheel to twist with a little breaker bar help?
Or hook it behind my rig with the flat tow kit & drop the clutch while moving? |
McMark |
Jun 19 2011, 09:33 AM
Good luck... (IMG:style_emoticons/default/sad.gif) locked engines are sucky. Do you have the spark plugs out? Just to make sure it's not hydrolocked. There is no shortage of dumb/crazy ideas to free it up. Besides the ol' tow-n-clutch-dump, there is the spray starting fluid in whichever cylinder has the valves closed, then install a spark plug and fire it off.
Not saying it's a good idea. (IMG:style_emoticons/default/wink.gif) |
messix |
Jun 19 2011, 10:09 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
pull the plugs and turn it over with a flywheel tool. it shouldn't have "rusted" it's an aluminum block..... does it iron liners?
JRust |
Jun 19 2011, 12:04 PM
I just had a thought. Amazing in itself i know. I have not taken this starter off yet. Maybe this starter is what is completely locked up. Im going to pull it this afternoon. Im hoping it will just be that starter. Its kind of a pain to get off with the adapter plate
Prospectfarms |
Jun 19 2011, 12:23 PM
Member Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest |
I just had a thought. Amazing in itself i know. I have not taken this starter off yet. Maybe this starter is what is completely locked up. Im going to pull it this afternoon. Im hoping it will just be that starter. Its kind of a pain to get off with the adapter plate Probably not your problem. For the starter gear to behave as a flywheel "lock" would mean both the solenoid and the overrun clutch are out of place and locked. More likely the starter itself is bad. A def. solenoid can actuate the gear ("click") but not engergize the starter motor. Should pull the starter anyway. You can test both theories. Good luck! |
messix |
Jun 19 2011, 12:29 PM
I just had a thought. Amazing in itself i know. I have not taken this starter off yet. Maybe this starter is what is completely locked up. Im going to pull it this afternoon. Im hoping it will just be that starter. Its kind of a pain to get off with the adapter plate it could be. pull it apart, starters are pretty simple, i've had to tear them apart on the trail, in the mud, in a hole, in the cold, soaking wet...... might be as easy as disassemble and freshen the brushes and lube the bushings and clean and lube the bendix. |
Mike Bellis |
Jun 19 2011, 05:03 PM
Get a big breaker bar on that crank and break it loose! (IMG:style_emoticons/default/evilgrin.gif) Strange that your engine would lock up just from sitting. You sure it diddn't drop during your move? (IMG:style_emoticons/default/poke.gif)
computers4kids |
Jun 19 2011, 08:03 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Jamie,
Since you just rebuilt the transmission is it possible something is binding, totally unrelated to the engine itself when you put it back together? |
messix |
Jun 19 2011, 08:22 PM
JRust |
Jun 19 2011, 08:28 PM
Jamie, Since you just rebuilt the transmission is it possible something is binding, totally unrelated to the engine itself when you put it back together? No that is totally impossible (IMG:style_emoticons/default/dry.gif) . Like I could screw that up (IMG:style_emoticons/default/blink.gif) Okay anything is possible. I am really leaning towards that starter being toast. Not only would explain all the problems I had with it. It is also very fixable. I didn't get to it today. Just enjoyed being a dad & letting the wife & kids wait on me all day (IMG:style_emoticons/default/biggrin.gif) . I even took a nap (IMG:style_emoticons/default/evilgrin.gif) . Pitiful I know & I won't get to do much with it tommorow because of work. I am off the rest of the week & will get to it first thing tuesday morning. Just be a bit of a pain to get the starter off. The nut on top has the ribs on the starter to hold it in place. That is no big deal on a normal motor as you get to the bolt. On my motor that bolt head is on the adapter plate & hidden. Anyone have a trick for getting the nut to come off? Probably just have to pull the tranny with adapter plate to do it. Just means unbolting the rest of the stuff involved (IMG:style_emoticons/default/dry.gif) . Oh well maybe the sucker will start with a new starter in place? I will make sure to test one on the bench before putting it in though (IMG:style_emoticons/default/headbang.gif) |
914Mike |
Jun 19 2011, 08:43 PM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
... Just be a bit of a pain to get the starter off. The nut on top has the ribs on the starter to hold it in place. That is no big deal on a normal motor as you get to the bolt. On my motor that bolt head is on the adapter plate & hidden. Anyone have a trick for getting the nut to come off? Probably just have to pull the tranny with adapter plate to do it. Just means unbolting the rest of the stuff involved (IMG:style_emoticons/default/dry.gif) . Oh well maybe the sucker will start with a new starter in place? I will make sure to test one on the bench before putting it in though (IMG:style_emoticons/default/headbang.gif) If the bolt is still metric (IMG:style_emoticons/default/confused24.gif) I would put a head-nut back on, once you get it apart. 15mmATF vs 17mmATF with the same thread, you might have an easier time next time... |
Lo-Fi Version | Time is now: 14th May 2024 - 12:38 AM |
