Question to autocrossers out there..., ... oil starvation |
BMXerror |
Jun 19 2011, 11:02 AM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Has anybody ever autocrossed without a deep oil sump and not had a problem with oil starvation? Due to a parts combination, I may have to lose mine, but I won't do so if it's gonna cost me an engine. I've got an external oil cooler so I've got plenty of capacity, but I just don't want it to starve under side loads. Asking for the benefit of others' years of experience. Thanks.
Mark D. |
jjackson |
Jun 19 2011, 02:43 PM
Member Group: Members Posts: 219 Joined: 5-October 10 From: maumelle, arkansas Member No.: 12,246 Region Association: None |
Has anybody ever autocrossed without a deep oil sump and not had a problem with oil starvation? Due to a parts combination, I may have to lose mine, but I won't do so if it's gonna cost me an engine. I've got an external oil cooler so I've got plenty of capacity, but I just don't want it to starve under side loads. Asking for the benefit of others' years of experience. Thanks. Mark D. Autocrossed for over ten years with stock class and street prepared teeners.Did not run a deep sump.Never had a problem-Always limited skid pad runs to a few laps.Ran deep sump on our prepared four banger -when we started making more than 150 horses.JJackson |
grantsfo |
Jun 19 2011, 03:34 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Can't you run a tuna can at minimum? I'd be worried given fact you run Qualcomm. That's more of a mini road course with elevation changes that you will want some level of protection. I'd be worried about longer duration turns where car isn't level.
I ran streets of willow and then 4 years of ax with only tuna can and never had issues with my 1.8 powered car. |
URY914 |
Jun 19 2011, 03:36 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,319 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
You'll be find of 90% of the course layouts. Be careful when you see the turns that are over 180 degrees where you are turning hard for over 6 seconds or so.
BMXerror |
Jun 19 2011, 03:41 PM
There is another option... It may just be time to go to dry sump. (IMG:style_emoticons/default/happy11.gif) Great info, guys.
Mark D. |
GaroldShaffer |
Jun 19 2011, 09:49 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I run just a tuna can. Never had any problems.
stewteral |
Jun 20 2011, 11:01 AM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
Has anybody ever autocrossed without a deep oil sump and not had a problem with oil starvation? Due to a parts combination, I may have to lose mine, but I won't do so if it's gonna cost me an engine. I've got an external oil cooler so I've got plenty of capacity, but I just don't want it to starve under side loads. Asking for the benefit of others' years of experience. Thanks. Mark D. Hi Mark, My Chevy V8-914 used to oil starve while on track. My cure was a 3-Qt ACCUSUMP (holds 2 Qts of oil) which hold high pressure oil in reserve to feed into the engine's main gallery the second the pressure drops. Since you already have an external oil cooler, you can just add an Accusump via a "T" fitting where the cooler feeds back into the engine. The only other bit needed is a valve to control use of the Accusump. Here's Summit Racing's page on Accusump options: http://www.summitracing.com/search/?keywor...usump&dds=1 For $175 - $185, it's a very affordable solution. Best, Terry |
ConeDodger |
Jun 20 2011, 11:09 AM
Apex killer! Group: Members Posts: 23,574 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I run a half quart high and have never had problems. I plan on running an Accusump with the new motor. Cheapest way to insure oil pressure IF I were to get into a starvation situation.
Chris Pincetich |
Jun 20 2011, 01:21 PM
I run just a tuna can. Never had any problems. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/beerchug.gif) |
DanT |
Jun 20 2011, 02:17 PM
Have run a tuna can on 4 different 914-4s...never seen a green light on track or at an ax....20+ years of running them that way! (IMG:style_emoticons/default/smile.gif)
ConeDodger |
Jun 20 2011, 02:19 PM
Have run a tuna can on 4 different 914-4s...never seen a green light on track or at an ax....20+ years of running them that way! (IMG:style_emoticons/default/smile.gif) Dan fails to mention that there is only 1/8th of an inch between his tuna can and the pavement. He runs them 914's low to the ground! (IMG:style_emoticons/default/laugh.gif) |
DanT |
Jun 20 2011, 02:25 PM
Have run a tuna can on 4 different 914-4s...never seen a green light on track or at an ax....20+ years of running them that way! (IMG:style_emoticons/default/smile.gif) Dan fails to mention that there is only 1/8th of an inch between his tuna can and the pavement. He runs them 914's low to the ground! (IMG:style_emoticons/default/laugh.gif) New one isn't that low Rob.....Konis won't let me go any lower! (IMG:style_emoticons/default/smile.gif) Need to find some threaded collars that will work with them. |
ConeDodger |
Jun 20 2011, 02:48 PM
Have run a tuna can on 4 different 914-4s...never seen a green light on track or at an ax....20+ years of running them that way! (IMG:style_emoticons/default/smile.gif) Dan fails to mention that there is only 1/8th of an inch between his tuna can and the pavement. He runs them 914's low to the ground! (IMG:style_emoticons/default/laugh.gif) New one isn't that low Rob.....Konis won't let me go any lower! (IMG:style_emoticons/default/smile.gif) Need to find some threaded collars that will work with them. Bradley hooked me up. I could go quite a bit lower with my Konis... |
URY914 |
Jun 20 2011, 02:54 PM
Randal |
Jun 20 2011, 06:02 PM
Has anybody ever autocrossed without a deep oil sump and not had a problem with oil starvation? Due to a parts combination, I may have to lose mine, but I won't do so if it's gonna cost me an engine. I've got an external oil cooler so I've got plenty of capacity, but I just don't want it to starve under side loads. Asking for the benefit of others' years of experience. Thanks. Mark D. My car is typically running flat out with side loads as great as I can carry. Have never had a problem with oil starvation, but I've always run an Accusump. Cheap insurance I think. |
BMXerror |
Jun 20 2011, 07:25 PM
Have run a tuna can on 4 different 914-4s...never seen a green light on track or at an ax....20+ years of running them that way! (IMG:style_emoticons/default/smile.gif) Dan fails to mention that there is only 1/8th of an inch between his tuna can and the pavement. He runs them 914's low to the ground! (IMG:style_emoticons/default/laugh.gif) Mine's a little towards the low side too. With the current deep sump my ground clearance is about 3". I think I'll do the tuna can for now and go to dry sump when I can afford it (probably when I build the full on DP motor). Given your combined experiences I doubt I will have problems, especially since I'm down on net grip anyways. Plus, I have a low pressure safety on the car, so I think the engine is safe. I just don't want to be tripping it mid-run. Thanks guys. Mark D. |
GeorgeRud |
Aug 2 2011, 08:20 PM
Back when both the 914s and I were young, I used to run a lot of track events, and oil starvation was a real problem on long sweepers (turn one at IRP, turn 3 at Blackhawk, etc.), even with a deep sump. I would also agree with the idea of an Accusump - cheap insurance that's easy to install.
Borderline |
Aug 2 2011, 10:40 PM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
I ran my 1911 for years with stock oil system and no problems. I've got a shallow tuna can on my 2366 now.
Aug 3 2011, 11:27 AM
Resident German Group: Admin Posts: 41,612 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I run a half quart high and have never had problems. (IMG:style_emoticons/default/agree.gif) That's what i used to do with my 1.7 and 2.0. Never had an issue either, even after i went to slicks. (IMG:style_emoticons/default/driving.gif) |
ottox914 |
Aug 12 2011, 09:47 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
I run a half quart high and have never had problems. (IMG:style_emoticons/default/agree.gif) That's what i used to do with my 1.7 and 2.0. Never had an issue either, even after i went to slicks. (IMG:style_emoticons/default/driving.gif) I run the tuna can and a 1/2 qt with no problems in 10+ yrs of autox. NA and turbo. |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:57 AM |
