Nader's Nightmare...and mine too build thread, 4/6/14 Update. |
914coop |
Jun 20 2011, 10:23 PM
Member Group: Members Posts: 214 Joined: 5-September 08 From: Minneapolis Member No.: 9,514 Region Association: Northstar Region |
Well after over two months it has finally arrived. (IMG:style_emoticons/default/piratenanner.gif) Guessing a lot of you are already familiar with this car. Previous threads are 914-6 Carrma and WOW, my "solid" car aint so solid, but now it is solid!, It is off jack stands!!!.
I bought this car for two reasons. First, back on moaners day 2010 my 76' was rear ended. Got a rear clip for it and was going to have Area 51 Werks straiten it out and put on my AA steel flares. This car handled most of that need. (flares will still need to be done) Second, I was planning on doing the five lug conversion. Had the parts to convert the 914 suspension to a five lug. (Modified 914-4 parts) This car was a huge upgrade as T.C. had converted it to a 911 setup both front and rear. Those of you who know me already know this is a car for my son Dan, as I am legally blind and for some reason the stare of Minnesota would rather I not operate a vehicle on the roads..... (IMG:style_emoticons/default/biggrin.gif) After some thought and checking Dan's finances (Porsche Purists Skip this paragraph) We have decided to put a 1966 Corvair 180 turbo in it. This engine will be modified slightly. Heads will have stainless valves and angled exhaust ports. Cam has been custom made by Cower Cams for more torque in the mid range and high end. Just waiting on the rebuild kit from Corvair Underground. We also will be changing the draw through Turbo to a dual carb blow through system. We have asked Steve Goodman (Corvair Guru) for advice as we started down this path. Set a goal to have it road worthy by the RRC this fall. Here are some pictures, sorry my son took the pictures and can not seem to center the subject. (IMG:http://www.914world.com/bbs2/uploads_offsite/i384.photobucket.com-9514-1308630203.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i384.photobucket.com-9514-1308630203.2.jpg) Still searching for a name, suggestions welcome. |
PanelBilly |
Jun 21 2011, 08:08 AM
914 Guru Group: Members Posts: 5,805 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
What prompted the covair engine?
Tom_T |
Jun 21 2011, 10:02 AM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
What prompted the covair engine? Maybe Doc Evil's Bus with a 'Vair motor & his spate of posts on them over the past year? Not bad powerplants & well supported parts-wise in the USA, plus the P-6 conversion could still be done later. I remember the guy in the earliest post from IN who TC got it from. It turned out he lived a couple of blocks from one of my brothers in Brooklyn IN. Odd the way this car has made the rounds about the country in just a couple of years, bouncing from north to south! (IMG:style_emoticons/default/biggrin.gif) Good Luck Coop & hope your son helps you out with it! (IMG:style_emoticons/default/beerchug.gif) |
914coop |
Jun 21 2011, 02:21 PM
What prompted the covair engine? Maybe Doc Evil's Bus with a 'Vair motor & his spate of posts on them over the past year? Not bad powerplants & well supported parts-wise in the USA, plus the P-6 conversion could still be done later. I remember the guy in the earliest post from IN who TC got it from. It turned out he lived a couple of blocks from one of my brothers in Brooklyn IN. Odd the way this car has made the rounds about the country in just a couple of years, bouncing from north to south! (IMG:style_emoticons/default/biggrin.gif) Good Luck Coop & hope your son helps you out with it! (IMG:style_emoticons/default/beerchug.gif) Yes Dr. Evils posts got me thinking, however I was still looking for the 911 engine. When it was clear that that was not in the cards (Wallet) right now the Corvair seemed like the perfect choice. No cutting or adding radiators and was substantially less expensive and still had the benefits of the bigger engine. As you had mentioned it can be removed for a 911 engine if desired down the road. Dan (My son) is the main worker on this car, I am just there to help and give advice since he has graduated this year and the car will be his when it is finished.. Hoping the next bounce down south will be because we drove it to a event instead of it being sold. |
Lo-Fi Version | Time is now: 15th May 2024 - 02:34 AM |
