Nader's Nightmare...and mine too build thread, 4/6/14 Update. |
914coop |
Jun 20 2011, 10:23 PM
Member Group: Members Posts: 214 Joined: 5-September 08 From: Minneapolis Member No.: 9,514 Region Association: Northstar Region |
Well after over two months it has finally arrived. (IMG:style_emoticons/default/piratenanner.gif) Guessing a lot of you are already familiar with this car. Previous threads are 914-6 Carrma and WOW, my "solid" car aint so solid, but now it is solid!, It is off jack stands!!!.
I bought this car for two reasons. First, back on moaners day 2010 my 76' was rear ended. Got a rear clip for it and was going to have Area 51 Werks straiten it out and put on my AA steel flares. This car handled most of that need. (flares will still need to be done) Second, I was planning on doing the five lug conversion. Had the parts to convert the 914 suspension to a five lug. (Modified 914-4 parts) This car was a huge upgrade as T.C. had converted it to a 911 setup both front and rear. Those of you who know me already know this is a car for my son Dan, as I am legally blind and for some reason the stare of Minnesota would rather I not operate a vehicle on the roads..... (IMG:style_emoticons/default/biggrin.gif) After some thought and checking Dan's finances (Porsche Purists Skip this paragraph) We have decided to put a 1966 Corvair 180 turbo in it. This engine will be modified slightly. Heads will have stainless valves and angled exhaust ports. Cam has been custom made by Cower Cams for more torque in the mid range and high end. Just waiting on the rebuild kit from Corvair Underground. We also will be changing the draw through Turbo to a dual carb blow through system. We have asked Steve Goodman (Corvair Guru) for advice as we started down this path. Set a goal to have it road worthy by the RRC this fall. Here are some pictures, sorry my son took the pictures and can not seem to center the subject. (IMG:http://www.914world.com/bbs2/uploads_offsite/i384.photobucket.com-9514-1308630203.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i384.photobucket.com-9514-1308630203.2.jpg) Still searching for a name, suggestions welcome. |
914coop |
Dec 11 2011, 03:04 PM
Well got the pistons and rods back Friday. Got rings on yesterday was trying to install them in the Cylinders. Will not go in (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/dry.gif) , stopped to think about it.
This morning I removed the rings and check fit. Can barely see light through the gap. Should be .007 to .040. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) Need to take the cylinders in to take a bit more off. Can't seem to catch a break!!!! (IMG:style_emoticons/default/dry.gif) |
rick 918-S |
Dec 11 2011, 03:48 PM
Hey nice rack! -Celette Group: Members Posts: 20,456 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Well got the pistons and rods back Friday. Got rings on yesterday was trying to install them in the Cylinders. Will not go in (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/dry.gif) , stopped to think about it. This morning I removed the rings and check fit. Can barely see light through the gap. Should be .007 to .040. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) Need to take the cylinders in to take a bit more off. Can't seem to catch a break!!!! (IMG:style_emoticons/default/dry.gif) Be sure to check the spec for the piston to wall clearance. If your piston to cylinder wall clearance is good you just need to file the ring end gaps. I have been cutting and welding for two days. I'll post photos later. The right rear flare is tacked and fitted. Just need to weld it up and work the puckers out of the stamping on the flares. |
914coop |
Dec 11 2011, 07:08 PM
Well got the pistons and rods back Friday. Got rings on yesterday was trying to install them in the Cylinders. Will not go in (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/dry.gif) , stopped to think about it. This morning I removed the rings and check fit. Can barely see light through the gap. Should be .007 to .040. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) Need to take the cylinders in to take a bit more off. Can't seem to catch a break!!!! (IMG:style_emoticons/default/dry.gif) Be sure to check the spec for the piston to wall clearance. If your piston to cylinder wall clearance is good you just need to file the ring end gaps. I have been cutting and welding for two days. I'll post photos later. The right rear flare is tacked and fitted. Just need to weld it up and work the puckers out of the stamping on the flares. Yep did that, thats why the cylinders are going in. Close but a little to small. Figure a hone will do it, but will leave that up to the professionals to decide whats best. Bringing piston and rings in so there is no question |
Lo-Fi Version | Time is now: 15th May 2024 - 03:19 AM |
