Nader's Nightmare...and mine too build thread, 4/6/14 Update. |
914coop |
Jun 20 2011, 10:23 PM
Member Group: Members Posts: 214 Joined: 5-September 08 From: Minneapolis Member No.: 9,514 Region Association: Northstar Region |
Well after over two months it has finally arrived. (IMG:style_emoticons/default/piratenanner.gif) Guessing a lot of you are already familiar with this car. Previous threads are 914-6 Carrma and WOW, my "solid" car aint so solid, but now it is solid!, It is off jack stands!!!.
I bought this car for two reasons. First, back on moaners day 2010 my 76' was rear ended. Got a rear clip for it and was going to have Area 51 Werks straiten it out and put on my AA steel flares. This car handled most of that need. (flares will still need to be done) Second, I was planning on doing the five lug conversion. Had the parts to convert the 914 suspension to a five lug. (Modified 914-4 parts) This car was a huge upgrade as T.C. had converted it to a 911 setup both front and rear. Those of you who know me already know this is a car for my son Dan, as I am legally blind and for some reason the stare of Minnesota would rather I not operate a vehicle on the roads..... (IMG:style_emoticons/default/biggrin.gif) After some thought and checking Dan's finances (Porsche Purists Skip this paragraph) We have decided to put a 1966 Corvair 180 turbo in it. This engine will be modified slightly. Heads will have stainless valves and angled exhaust ports. Cam has been custom made by Cower Cams for more torque in the mid range and high end. Just waiting on the rebuild kit from Corvair Underground. We also will be changing the draw through Turbo to a dual carb blow through system. We have asked Steve Goodman (Corvair Guru) for advice as we started down this path. Set a goal to have it road worthy by the RRC this fall. Here are some pictures, sorry my son took the pictures and can not seem to center the subject. (IMG:http://www.914world.com/bbs2/uploads_offsite/i384.photobucket.com-9514-1308630203.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i384.photobucket.com-9514-1308630203.2.jpg) Still searching for a name, suggestions welcome. |
914coop |
Jun 30 2012, 11:04 AM
Well engine is in the car, not fully secure but in the car. Fits nice as long as you cut off the oil filter mount and remove the original Corvair engine mount plate..
(IMG:http://www.914world.com/bbs2/uploads_offsite/i384.photobucket.com-9514-1341075841.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i384.photobucket.com-9514-1341075842.2.jpg) Made monting it more difficult because of choosing a aluminum finned oil pan which took away a 1 1/4 inch of clearance from the enging mount bar, going to be a tight fit. May have to lower the bar a bit depending on final mount design. Going to be a bit before it is started. Since I did not take the engine out I need to figure out what wires go where. Also need to fab up the engine mount and there is the filter mount I cut. I think I have two options, Weld in AN fittings where I cut it off and do a remote filter and cooler. Will need to angle cut at least one of them to allow room to thighten fittings to them. Other option that may work is to weld the holes shut and remove the pressure switch, drill a hole at the other 90 degree angle and add AN fittings there. Then do a remote filter, cooler and pressure switch mount. Here are pictures of the cut filter and mounting plate. (IMG:http://www.914world.com/bbs2/uploads_offsite/i384.photobucket.com-9514-1341075842.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i384.photobucket.com-9514-1341075842.4.jpg) Here is the engine before it went into the car. (IMG:http://www.914world.com/bbs2/uploads_offsite/i384.photobucket.com-9514-1341075843.5.jpg) Need to find wiring digrams for the engine compartment, Haynes is to small for me to read. Irv |
Lo-Fi Version | Time is now: 14th May 2024 - 09:41 PM |
