Suspension Setup and Cages?????, at what point do you NEED a cage, or not |
Mueller |
Jun 15 2004, 09:23 PM
I've been reading all the suspension improvments that Trekkor has been doing, the car is getting stiffer/stronger parts on it, but how much more effective would all these parts be if a cage was installed?
has anyone done back to back testing without and then with a cage with no other changes??? |
machina |
Jun 21 2004, 12:11 PM
I think that the rear tubes are optional anyway on cars with our layout. Many I have seen do not run any rear bars. I have not had a problem with SCCA scrutineer or yearly tech yet.
Guess I could hack them out if I had to. (IMG:style_emoticons/default/sawzall-smiley.gif) dr |
groot |
Jun 21 2004, 01:01 PM
Dis member Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
There are some other rules in that section that apply to all cars that aren't well known.
For example: Main hoop: 4 bends maximum, totaling 180 degrees, +- 10 degrees and Front hoop: 4 bends maximum, or front downtubes, 2 bends maximum. There is a "get out of jail" card that says you can use tubing the next size up if you don't meet the requirements. I think there are some scrutineers that don't know this section well enough. BTW... if you're talking production, those tubes are not optional. |
Brett W |
Jun 21 2004, 04:39 PM
When does a car need a roll cage?
When it leaves the showroom! If you want the maximum in suspension accuracy then the chassis needs to be built with the maximum stiffness. We did a car awhile back that used 1 3/4 .095 instead of 1.5 figuring the trade off in stiffness would be worth the wieght. I really don't think is was. The problem with most cages available for the 914 on the market, (Autopower, Etc) don't address the stiffening issue they just add a measure of safety. A good cage should incorporate the whole suspension, chassis and body. Tubes in the right place can make a difference, where just adding a bunch of tubes can just add wieght. I would love to run a scale model of the 914 chassis through an FEA program but I don't know How to get the measurements without a CMM. |
Trekkor |
Jun 21 2004, 05:39 PM
Just installed the interior longs chassis stiffening plates today.
I can already feel the differance. But I haven't really *tested* it yet. |
Lo-Fi Version | Time is now: 28th May 2024 - 10:02 PM |
