I want a 914 that can swim ? |
porsche4me |
Jun 26 2011, 09:35 PM
Member Group: Members Posts: 54 Joined: 27-March 03 From: savannah Member No.: 483 Region Association: None |
I want to build a 914 that can swim at least as fast as a type 166 vw or the amphicar
http://en.wikipedia.org/wiki/Volkswagen_Schwimmwagen this guy is amazing ---- http://www.thesamba.com/vw/forum/viewtopic...b68f3cb669ebb5f but I dont want to make it look like anything else --- just drive to the boat ramp --- go in the water do 5-10 mph and drive out ---- |
porsche4me |
Jun 26 2011, 09:40 PM
may need a trans with a pto --- or front trans from a 4 wheel drive car ---- with a prop shaft
or just a seadoo motor in the trunk -----with a jet drive |
timothy_nd28 |
Jun 26 2011, 09:55 PM
gallons and gallons of seam sealer!!!
porsche4me |
Jun 26 2011, 10:09 PM
laying under a parts 914 with no motor or trans with a 16 foot jon boat next to me on a trailer ---- made me think of this again after 15 years of not thinking about this -
wingnut86 |
Jun 26 2011, 10:31 PM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
Awesome.
Do It! Rust won't be an issue;-) |
Mike Bellis |
Jun 26 2011, 11:26 PM
Just re-body an Amficar. Or weld the doors shut and every other hole. Not sure how long it would float. You have your work cut out for you.
budk |
Jun 27 2011, 06:50 AM
Yes! It's a Bumblebee! Group: Members Posts: 678 Joined: 24-July 10 From: Hickory, PA Member No.: 11,970 Region Association: MidAtlantic Region |
Pontoons + Jack Stands + 914
(IMG:style_emoticons/default/beerchug.gif) |
FourBlades |
Jun 27 2011, 11:49 AM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
Low pressure expanding foam in the longs... and life jackets. |
Drums66 |
Jun 27 2011, 11:55 AM
.....and as much fiber-glass as possible (IMG:style_emoticons/default/poke.gif)
(IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif) ( no salt water) (IMG:style_emoticons/default/bye1.gif) |
porsche4me |
Jun 27 2011, 10:06 PM
i need an idea about how to use the 914 motror to drive a prop out the back ????
bare 1 |
Jun 27 2011, 10:12 PM
Member Group: Members Posts: 122 Joined: 27-October 04 From: Apache Junction viaWhidbey Is. Member No.: 3,019 Region Association: None |
ditch the transaxle----- direct drive!!!!
Mike Bellis |
Jun 27 2011, 10:49 PM
Dune buggy paddle tires
VaccaRabite |
Jun 28 2011, 06:49 AM
The motor is not the problem to drive the prop. The transaxle is. You need a pto shaft, which means some sort of transfer case or a 4WD selectable transaxle. No would have to adapt a different transmission to the T4. Maybe one out of an Eagle or a Brat. Not sure of the drive train on those.
Zach |
pktzygt |
Jun 28 2011, 07:31 AM
Member Group: Members Posts: 328 Joined: 20-March 07 From: Chesapeake, VA Member No.: 7,611 Region Association: MidAtlantic Region |
The motor is not the problem to drive the prop. The transaxle is. You need a pto shaft, which means some sort of transfer case or a 4WD selectable transaxle. No would have to adapt a different transmission to the T4. Maybe one out of an Eagle or a Brat. Not sure of the drive train on those. Zach Many of those old subys had a selectable transfer case. Even some of the more common ones like the legacy. You could probably reverse engineer an adapter plate, flywheel and clutch that we use in the suby conversions of just go suby power. I mean if you're going to do something crazy you might as well do something crazy right? I hope someone actually does this. I don't think I have enough years on my life to complete all the strange projects I've thought up. |
Mark Henry |
Jun 28 2011, 09:18 AM
If i was going to that much trouble I'd rather build this:
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.914-6-club.de-26-1309274307.1.jpg) ....and pull a real boat with it. (IMG:style_emoticons/default/smile.gif) better pics http://www.914world.com/bbs2/index.php?sho...amp;pid=1439415 |
balljoint |
Jun 28 2011, 09:26 AM
You will be building an Unterseeboot.
https://www.youtube.com/watch?v=Rc4r4oaGs7A https://www.youtube.com/watch?v=GU-Lbf4jGjc |
Lo-Fi Version | Time is now: 13th May 2024 - 06:31 AM |
