14 pin connector assignments, need 75 pinout for suby conversion |
jpnovak |
Jun 30 2011, 09:04 PM
They call me "Nanoman" Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region |
I have just about completed the wiring for my $2011 GRM Challenge car.
I am converting a 1975 914 to WRX powertrain. The car came as a roller and the 14 pin connector shell was missing. Just dangling wires so I have no reference for pin position. I just have to connect the battery and have a few wiring connections. I am only using the following connectoins: yellow starter wire (pin1 on my 911) blk/pur tach wire blue alternator field wire black alternator wire The two red wires is my confusion. I think these both go to batt+ Are either switched 12V? On my 911 there is both 12V hot and 12V switched. I would assume the larger diameter wires is 12V hot and the smaller diameter is 12V switched. Can anyone confirm? Thanks. I am hoping to fire the engine for the first time this weekend. |
Mike Bellis |
Jun 30 2011, 09:11 PM
The reds go to the battery. One ends up at the fuse panel and the other goes to the ignition switch to give it power.
jpnovak |
Jul 1 2011, 08:16 AM
Thanks Mike,
I just found a wiring diagram on PP. Here are the assignments. T14-pin 12 is power to the relay panel direct from the battery T14-pin 14 is also power to the relay panel through the engine compartment fuse. Both Pin 14 and Pin 12 attach directly to the battery. A separate 12V hot connects the battery to the starter and then to the alternator. There is a separate battery connection that is two red wires coming off a ring terminal at the battery. These go to the wiper switch and ignition switch. A black wire comes from the ignition switch to T14-Pin8 for 12V switched. I now have everything I need for final engine connections. With luck I might get the car started this weekend. |
Lo-Fi Version | Time is now: 20th May 2024 - 08:17 AM |
