Fuel pump options for 73 injected model |
maddhatter |
Jul 5 2011, 11:20 AM
Newbie Group: Members Posts: 7 Joined: 5-July 11 From: Clementon, NJ Member No.: 13,279 Region Association: None |
I recently picked up a 73 1.7 that had been stored inside for 20 years. The body is great as expected sitting inside, but the fuel pump does not work among other things and looking for a replacement I see that they are no longer made. Great! Can I retrofit a later model pump to fit my car? I thought the injection systems were pretty much the same all the way through the years, but the newer pumps look vastly different from my hunk of metal pump, mine having 3 hose connections and the newer ones only the typical two. Thanks in advance.
TheCabinetmaker |
Jul 5 2011, 11:58 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
New early model pumps are available, but run about 300 bucks. You can use the late (75/76) pump. its about 175. Or, you can a get a bosch pump from napa, part #N69133 for around 30 bucks. Its the identical pump used by the late model cars.
Lo-Fi Version | Time is now: 16th May 2024 - 05:54 AM |
