Fuel pump options for 73 injected model |
maddhatter |
Jul 5 2011, 11:20 AM
Newbie Group: Members Posts: 7 Joined: 5-July 11 From: Clementon, NJ Member No.: 13,279 Region Association: None |
I recently picked up a 73 1.7 that had been stored inside for 20 years. The body is great as expected sitting inside, but the fuel pump does not work among other things and looking for a replacement I see that they are no longer made. Great! Can I retrofit a later model pump to fit my car? I thought the injection systems were pretty much the same all the way through the years, but the newer pumps look vastly different from my hunk of metal pump, mine having 3 hose connections and the newer ones only the typical two. Thanks in advance.
SteveL |
Sep 30 2014, 12:51 PM
Senior Member Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
In the picture above, the pump has been moved to the lower firewall. Can it be left in the stock location on the existing rubber mounts?
If you move it to the firewall, is it loud inside the cabin? Just drill a couple of holes in the firewall for a bracket? Thanks |
EdwardBlume |
Sep 30 2014, 12:57 PM
In the picture above, the pump has been moved to the lower firewall. Can it be left in the stock location on the existing rubber mounts? If you move it to the firewall, is it loud inside the cabin? Just drill a couple of holes in the firewall for a bracket? Thanks You can try anything you want. The stock pump comes and goes the same side where the new pump passes from one side to the other. You also have the fuel filter. Plus the fuel pump isn't the easiest thing in the world to attach. I did mine a few months ago just as pictured with excellent results. |
914_teener |
Sep 30 2014, 02:11 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
In the picture above, the pump has been moved to the lower firewall. Can it be left in the stock location on the existing rubber mounts? If you move it to the firewall, is it loud inside the cabin? Just drill a couple of holes in the firewall for a bracket? Thanks You can try anything you want. The stock pump comes and goes the same side where the new pump passes from one side to the other. You also have the fuel filter. Plus the fuel pump isn't the easiest thing in the world to attach. I did mine a few months ago just as pictured with excellent results. I did mine also as pictured above a while ago Easy.....I've driven in 110 ambient temps in So Cal. It was an easy install with no problems. |
Lo-Fi Version | Time is now: 16th May 2024 - 02:34 AM |
