Los Angeles: 1963 VW double cab bus (LA) $60000 |
914World |
Jul 14 2011, 11:13 PM
Member #1 Group: Members Posts: 130,681 Joined: 23-December 02 From: World Wide Web Member No.: 1 Region Association: None |
1963 VW Double Cab Truck
Transmission • Type 1 VW swing axle with a Freeway Flyer gear ratio. Engine • Porsche 914 2 liter • Built to 2365 cc with Scat Pistons and cylinders • Fat Performance Cam • Fat Performance 911 Porsche fan conversion • Fat performance Stainless Steel Valves • CB performance fuel injection setup • External oil filter and oil cooler with thermostat fan • Custom exhaust with 1 5/8" primary and header pipes • Flow Master cross flow muffler Body- • Media Blasted to bare metal. • Rust repair was done, new floors, front wheel arches, frame supports • Roof section was from a 21 window bus, original slider top • Complete paint and bodywork, Undercoated with Spray bedliner in bed and underbody. Brakes • Porsche 944 front disc brakes • So Cal Imports rear disc brake conversion with Porsche 5 on 130 mm bolt pattern • Duel master cylinder Interior • Seat covers came from Sew Fine interiors Suspension • Dropped and reinforced front spindles setup for disc brakes from Wagons West • Narrowed front suspension beam set up with inboard airbags • Modified rear spring plates with Air Ride • Air Ride air bags with compressor and tank mounted behind rear seat. Wheels • Factory Porsche Boxter Twist 7 X 17 Misc. • Converted to 12 Volt • Wolfsburg West Front flip out Safari Windows Email Me If Interested And For More Pictures
Lo-Fi Version | Time is now: 18th May 2024 - 04:24 AM |
