Modesto: F/S 914 goodies stash must l@@k Porsche (last chanceville) |
914World |
Jul 20 2011, 03:58 PM
Member #1 Group: Members Posts: 130,681 Joined: 23-December 02 From: World Wide Web Member No.: 1 Region Association: None |
To help you know exactly what you're paying, MOST every item I covered shipping cost, a few heavy/bulky items I did leave open to actual cost. These are my personal stash for my 73 I just sold. EXTERIOR 1] fuel sending unit w/ extra ring & mounting hardware misc. $75 shipped 1] engine trunk lid complete w/ grill solid west coast part $75 + shipping 1] bumper dog bone $10 shipped 1] door handle GREAT chrome, damage to lock release fork (finger broke)repairable? $20 shipped One of the two little "fingers" that move the plastic lock peice (that always seem to need to be placed) got broke during an attempt to change out the plastic piece. I'm hoping that someone has more patience than myself to salvage this otherwise excellent part. 1] excellent rear trunk drain funnel $12 shipped LIGHTING & ELECTRICAL 1] side marker light base $15 shipped 1] fuel sending unit w/ring & misc. attaching hardware $75 shipped 1] cut alt harness (good 4 alt plug body or pigtail) $15 shipped 1] wiper switch excellent $50 shipped 1] emergency switch excellent $50 shipped 1] 72 turn signal switch $30 shipped INTERIOR 1] set of "butt breathing" fabric seat inserts, both w/ good sensors {worn material} great to temporary swap in for hot sweaty days or long drives $65 shipped 1] 12 ft. of special twisted CHT wire (I'll measure soon) $25 shipped shipped 1] used turn signal switch (no harness)$15 shipped shipped 1] Custom vinyl covered 6 gauge console face panel, unfinished project. Set up for rocker switches and multiple lighting, comes with misc. add your gauge selection and finish $50 shipped 1] VDO oil temp. gauge $15 shipped 1] S/W 30 amp. Gauge $15 shipped 1] S/W oil temp. gauge $15 shipped 1] S/W vacuum gauge $15 shipped [b][color="#FF0000"]SOLD[/color][/b] 1] batch of misc. gauge brackets & lights $15 shipped Or. . . ALL above gauges, brackets and panel $85 shipped 1] 12 FT. of special spiral CHT wire $10 shipped 1] 72 up dash vent $25 shipped 1] sun visor center mount bracket $10 shipped ENGINE 1] Header w/ glass pack -after heat exchangers $75 + shipping 1] complete engine set of 1.7rockers for swivel conversion (no swivels or machining) $80 shipped 4] 1.7 high compression raised dome "euro" pistons and wrist pins $95 shipped 4] 96mm flat top pistons, pins and rings w/ rings $85 shipped 1] set of 4 very nice 1.7 rods (reconditioned?) $55 shipped 4] injector hold downs $20 SHIPPPED 1] j-tube great shape $25 shipped 1] set of decent j-tube tin seals $20 shipped 1] good used starter $65 shipped 1] ribbed/insulated heat tube $20 shipped 1] NON sending unit oil cover and screen $20 shipped 1] cut alt harness (good 4 alt plug body or pigtail) $15 shipped 1] oil cap $10 shipped 1] excellent rear trunk drain funnel $12 shipped 2] good used oil pumps $30 each shipped shipped or $50 both shipped 1] evaporative canister with securing hardware $30 shipped 2] used great shape o.e. oil pumps each $25 shipped 1] NEW set of Napa Echlin points & condensor $30 SHIPPED 1] M.P.S. 75? 2.0 #0231172021 022906051E unmolested cap, W/ mounting bracket $55 SHIPPED 3] 2.0 plenum sensors $30 SHIPPED 1] cold enrich injector (pass thru routing) $30 SHIPPED 1] cold enrich injector $30 SHIPPED DRIVETRAIN 1] O.E. steelie beauty ring $30 shipped 1] set of stub axles $30 shipped 2] main e-brake brake cables very nice condition $ 75 shipped
Lo-Fi Version | Time is now: 19th May 2024 - 02:42 PM |
