1.8 L-Jet with some 2.0 parts, What is missing ? |
jim_hoyland |
Jul 21 2011, 05:49 PM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The 1.8 L-Jet was rebuilt several years ago. The mechanic installed a 2.0 crank and larger pistons. It's still FI and runs fine-but not quite like a 2 liter
Does the motor require 2.0 heads to get the extra hp ? or is ther more to this ?? Attached image(s) |
SLITS |
Jul 21 2011, 05:53 PM
Horsepower is all about the characteristics of the heads ....
jim_hoyland |
Jul 21 2011, 05:56 PM
Cap'n Krusty |
Jul 21 2011, 07:05 PM
Yes. There will, of course, be intake manifold issues, but you can work around them.
Edit: Another issue may be the configuration of the pistons. Bus pistons have a substantial dish, and work well with earlier heads because of the smaller size of the combustion chamber. The Cap'n |
Als914 |
Jul 21 2011, 07:08 PM
Lighting my way Group: Members Posts: 330 Joined: 1-January 06 From: Hemet,Ca. Member No.: 5,346 Region Association: Southern California |
Horsepower is all about the characteristics of the heads .... Would 2 liter heads be a bolt on ? IIRC (IMG:style_emoticons/default/idea.gif) , the 2.0 heads would be a bolt on but because the spark plug location is different than the 1.8's you would need the 2.0 cooling tin over the head area. BTW, I did that conversion to my 1.8 which is now a 2056 L-jet with a mild cam. My intake and exhaust valves on my 1.8 heads were increased to 2.0 spec. |
Bleyseng |
Jul 22 2011, 12:05 AM
Hard to know what the mechanic used but 2.0L crank with bus pistons gives you 7.3 to 1 CR with Bus heads (which have a smaller chamber). Same setup with 1.8L heads (52CC chamber) is even less CR.
914 2.0L heads are 55cc so with bus pistons your CR falls even lower. You have to match the whole setup to get the HP- 2.0L USA or Euro flat top pistons and 914 2.0L heads to get the 100hp. Bus stuff gets you 67hp...... |
sean_v8_914 |
Jul 22 2011, 07:22 AM
I run into so many engines where the guy who built it doesnt even know how to set compression or what head cc means.
even if you pull the valve covers to see what heads you have, its hard to say how deeply they are fly cut, did he use head gaskets, what shims are under the barrels... if it runs well, leave it alone |
jim_hoyland |
Jul 22 2011, 07:30 AM
Thanks for the input; I'll stop by and ask about the parts mentioned above. Yes it runs really good, I drive it daily. Will post my findings... (IMG:style_emoticons/default/smile.gif)
jim_hoyland |
Jul 22 2011, 01:43 PM
Talked to mechanic this a.m. to answer some of the questions:
1. Valves are 1.8 2. Not bus pistons, but flat top 3. No flycut made at rebuild 4. No shims under barrels His thought on perfirmance is related to the AFM setting/throttle body size, and possibly the injectors. |
sean_v8_914 |
Jul 22 2011, 10:02 PM
I would stick my wide band meter up its tail pipe. AFR should be checked.
sean_v8_914 |
L jet is tunable
Lo-Fi Version | Time is now: 17th May 2024 - 08:40 PM |
