mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,935 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
Lately I noticed I could feel play in the fronts when the car is
on the ground and pull/push on the top of the tire. However, doublechecking the wheelbearings shows they are tight (i.e. washer is just moveable). Also I had put in new ball joints only a year ago. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) What could make that happen? This is on the -6, so I even checked that the hub-to-brake-disc bolts are tight. The play is not a huge amount but I want to get rid of it if it's not right, and don't want anything to get worse. Thanks, |
Lo-Fi Version | Time is now: 11th July 2025 - 09:10 AM |
