Rear Wheel Bearing Interference Fit |
wndsrfr |
Jul 24 2011, 07:09 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
So, now with the trailing arm off & old bearing out & new timken in freezer I started to measure with my digital calipers & get:
Trailing Arm recess=2.950" room temp (95F today) Bearing O.D. =2.9525" cold (maybe 20F) Interference = .0025" Is 2 1/2 thousandths OK? I'll heat the trailing arm recess prior to installing, but bet I'll only gain maybe a thousandth, leaving 1 1/2 thou interference for the press to overcome.... But, the next question is more disturbing...the hub to ID of the bearing is: Hub O.D. = 1.6520" warm Bearing I.D. = 1.6475" cold Interference = .0045" Of course I've put the hub into the freezer and will wait for the bearing to come to room temp prior to assembly, but I'm guessing I'll still be dealing with .003" interference there and that seems like a lot....need someone with bearing fit tolerances to chime in here.....anyone? |
Lo-Fi Version | Time is now: 1st June 2024 - 02:11 AM |
