Rich running D-Jet |
brenz |
Jul 27 2011, 10:24 AM
Member Group: Members Posts: 56 Joined: 10-March 10 From: Delaware, USA Member No.: 11,451 Region Association: MidAtlantic Region |
You need to put some heat to the CHT and see if the values change, should decrease. If not, it will cause the ECU to see the engine as cold and give a rich mixture. Tom In order to do this I'm thinking just run the engine for a few minutes and then shut it off and recheck the resistance? I haven't really looked, how hard is it to pull the head temp sensor? I don't really think this is the problem because it's running rich even when first started, but I'll double check it anyway. You don't need to pull the CHT to check the resistance. It grounds on the engine case. Only pull it if it checks out bad. It's probably fine though. Make sure all cylinders are firing. If it's trigger points it would be 2,3 or 1,4. Which plugs are clean and which are fouled? Injectors for the clean plugs might not be firing or the injectors for the fouled plugs could be leaking. Check your wiring if you didn't already. Then pull out the injectors from the head but leave them connected to the fuel line. Put them in glass jars and run the pump. They should squirt a little fuel. If one or more doesn't or if one or more leak, get them cleaned. |
biggy72 |
Jul 28 2011, 10:23 PM
Member Group: Members Posts: 209 Joined: 14-January 06 From: Olympia, WA Member No.: 5,418 Region Association: Pacific Northwest |
My CHT resistance is going down as it gets warmer. I checked my vacuum and it looks like I'm pulling close to 15 psi at around 900 rpm. Cylinders 1 and 4 are not nearly as warm as 2 and 3. Does this signal a trigger point problem? I haven't pulled my injectors to check them yet, but a trigger point problem will show up in the injectors too so.... if the cylinders indicate a problem with them I'll work on that first.
biggy72 |
Jul 28 2011, 11:08 PM
Well it looks like my brand new distributor cap has loose terminals for 3 out of the 4 plugs. They spun in place and the rotor started grinding into them. Hopefully a new cap and rotor will fix this, and hopefully with a little complaining I should get them for free since this engine has all of about an hour on it since the new cap and rotor went on. The cap even says "MADE IN THE USA" inside of it..... guess I should have gotten a Chinese one.
TheCabinetmaker |
Jul 29 2011, 04:14 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Buy a bosch cap and rotor.
remove trigger points, clean, relube, and reinstall. They fire in pairs. 1&4, 3&2. |
biggy72 |
Jul 29 2011, 07:15 AM
I've got a petronix setup, but it was definitely dirty in there from all of the grinding....
Bartlett 914 |
Jul 29 2011, 03:18 PM
biggy72 |
Jul 29 2011, 03:26 PM
Oh ok, thought you were talking about the points. I won't be able touch it until Sunday night, but I should be able to go through everything pretty quickly.
What kind of lube do you suggest for the trigger points? Regular grease? dielectric grease? some other special lube? |
Jul 29 2011, 04:54 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Bosch distributor grease on the rubbing blocks, where they ride on the cam. Just like regular points get.
One tube of Bosch distributor grease will last you a lifetime. More than one lifetime, if you've got a Pertronix in your car. All of your favorite Porsche parts places will carry it. --DD |
jcd914 |
Jul 29 2011, 11:01 PM
I've got a petronix setup, but it was definitely dirty in there from all of the grinding.... Don't confuse the pertronics with the trigger points. These are different animals in the distributor This has always been my problem with electronic ignition in 914's. Once the electronics are installed and the ignition points don't need maintenance people tend to forget that there are other parts of the distributor that do still need maintenance. At a tune-up I would pull the distributor and clean and lube the advance weights, apply oil to the felt button under the rotor and clean and lube the FI points. Add a new distributor o-ring and put it back in. If our Sun distributor machine was working I would check the advance and set the dwell while the distributor was out. Customers that had an added in electronic ignition, seldom wanted to pay for distributor servicing since "it doesn't have points anymore". Jim |
Prospectfarms |
Jul 30 2011, 05:40 AM
Member Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest |
I've got a petronix setup, but it was definitely dirty in there from all of the grinding.... Don't confuse the pertronics with the trigger points. These are different animals in the distributor This has always been my problem with electronic ignition in 914's. Once the electronics are installed and the ignition points don't need maintenance people tend to forget that there are other parts of the distributor that do still need maintenance. At a tune-up I would pull the distributor and clean and lube the advance weights, apply oil to the felt button under the rotor and clean and lube the FI points. Add a new distributor o-ring and put it back in. If our Sun distributor machine was working I would check the advance and set the dwell while the distributor was out. Customers that had an added in electronic ignition, seldom wanted to pay for distributor servicing since "it doesn't have points anymore". Jim OT ? : jcd914, I assume you pulled the distributors to replace points, along with performing the testing and lube you just described, and then timed those motors after reinstalling the distributor? I dislike pulling my dizzy 'cause re- timing the ignition takes three hands on my 1.7. To pull it, I have to turn the dizzy to access the retaining nut underneath the advance can--ruining my hard-won timing. Now it's time to freshen up those injector points, so I'm wondering if you recall any procedures that served to save time (so to speak) during the dizzy remove/motor tune-up process, back when you were pulling all those distributors? |
jcd914 |
Jul 30 2011, 12:00 PM
OT ? : jcd914, I assume you pulled the distributors to replace points, along with performing the testing and lube you just described, and then timed those motors after reinstalling the distributor? I dislike pulling my dizzy 'cause re- timing the ignition takes three hands on my 1.7. To pull it, I have to turn the dizzy to access the retaining nut underneath the advance can--ruining my hard-won timing. Now it's time to freshen up those injector points, so I'm wondering if you recall any procedures that served to save time (so to speak) during the dizzy remove/motor tune-up process, back when you were pulling all those distributors? I use a 13mm distributor wrench to reach under the advance and loosen the nut holding the distributor bracket to the case. Then I use my finger tips to remove the nut and washers so I can pull out the distributor. This keeps the timing close to where it was when the dist goes back in but I always checked and adjusted the timing after. You have to pull the distributor to remove the FI trigger points which need to be cleaned and lubed anyway. So it was just a standard routine for me. Pull the dist and take care of everything at once. Replacing the ignition points only adds 5 minutes or so to the whole process. Jim |
biggy72 |
Aug 1 2011, 11:51 PM
I figured it out finally. Replaced the cap and rotor because of the above problems. Still had a miss on 1 and 4 so I pulled the distributor out and checked continuity on the trigger points while I spun the shaft. One of the side was working, the other side was not. I pulled it apart and cleaned everything really well, checked everything by hand and it all looked ok. Put it back in and still had the same issue. I tried moving the trigger points around side to side and then retightening and that didn't help either.
So I pulled out my spare distributor that's pretty cruddy inside and cleaned those trigger points and then reinstalled them in my better distributor. After setting the timing we're back on all 4 cylinders. I should probably get a new set just in case I have another problem. Does anyone make them new? |
biggy72 |
Aug 2 2011, 12:16 AM
Has anyone tried getting one of these remanufactured distributors?
https://www.napaonline.com/Catalog/CatalogI...2+50062+2062020 I see AA has trigger points for $202 and was thinking a nice remanufactured distributor might be a better solution if it's that cheap. |
Prospectfarms |
Aug 2 2011, 08:50 AM
OT ? : jcd914, I assume you pulled the distributors to replace points, along with performing the testing and lube you just described, and then timed those motors after reinstalling the distributor? I dislike pulling my dizzy 'cause re- timing the ignition takes three hands on my 1.7. To pull it, I have to turn the dizzy to access the retaining nut underneath the advance can--ruining my hard-won timing. Now it's time to freshen up those injector points, so I'm wondering if you recall any procedures that served to save time (so to speak) during the dizzy remove/motor tune-up process, back when you were pulling all those distributors? I use a 13mm distributor wrench to reach under the advance and loosen the nut holding the distributor bracket to the case. Then I use my finger tips to remove the nut and washers so I can pull out the distributor. This keeps the timing close to where it was when the dist goes back in but I always checked and adjusted the timing after. You have to pull the distributor to remove the FI trigger points which need to be cleaned and lubed anyway. So it was just a standard routine for me. Pull the dist and take care of everything at once. Replacing the ignition points only adds 5 minutes or so to the whole process. Jim, Thanks for that information. Answered my question. Sounds like Biggy72 has solved his engine problem. As far as reliability of NAPA rebuilt distributor, there seems to be a consensus that the commonly available rebuilt dizzy's are not a good value. You should ask NAPA who does their work. There are folks on this board and at the SAMBA that have excellent reputations for rebuilding dizzy's, perhaps they might have a good source for the points. I have no personal experience beyond taking my unit apart and cleaning it two months ago (and forgetting to clean and lubricate the injector points!) |
Lo-Fi Version | Time is now: 31st May 2024 - 10:41 PM |
