Rear Soft brake line replacement, Engine out? |
swl |
Aug 4 2011, 08:48 AM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
it seems like a dumb question but how do I know what master cylinder is on the car. Brakes are REALLY firm. Way too firm for my liking. I feel like I would need two feet for panic braking.
dflesburg |
Aug 4 2011, 08:55 AM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
they have a number cast into the side should be 17 19 or 2x I think
Eric_Shea |
Aug 4 2011, 09:26 AM
With a mirror.
The number is cast on the top by the union where it bolts to the firewall. |
swl |
Aug 4 2011, 10:35 AM
of course it's on top! Why put it someplace where you can see it?
Car is off getting its safety done will have to wait until it gets home to have a peek. Eric is there anything else that would add to pedal effort? Calipers are rebuilt. I haven't replaced the soft brake lines but that is next on the list. I don't suspect them though since the brakes are so rock hard - no spongyness. Pads are new but just stock - no fancy racing compounds. |
swl |
Aug 4 2011, 09:15 PM
can't see anything - cylinder is really badly corroded. My mechanic says it might improve a bit as the pads and disks scuff up so I'll give it a bit of work and then make the call. Probably will wind up pulling it out and cleaning it up. looks like there may have been (be some) leaking somewhere. Best to go in and look soon.
Eric_Shea |
Aug 4 2011, 09:54 PM
Most people complain of just the opposite and, as the pads wear in, the pedal usually gets harder.
I would check out everything right now. Did you do anything recently? Rebuilt calipers? Try the pad bedding procedure on my site. Then go around and check every wheel/caliper. See if they're all the same temperature (careful, they could get very hot). While you're doing that, see if it pulls to one side or the other. Your condition means you either have pressure building in the system or you have a larger 23mm MC. Could be an aftermarket MC that does not have the proper markings and is over-sized. |
swl |
Aug 5 2011, 06:07 AM
This is a new to me car Eric. Not on the road yet other than testing. DaveP rebuilt the calipers for me and I've installed new rotors. It is possible that I could have messed up the venting clearance on the rears so I'll have another check down there. I am concerned about the soft lines so they come next.
I like the theory that they are bigger than 19. The amount of corrosion fits with aftermarket. I should probably just bite the bullet and buy a new 17. Brake travel never bothered me back in the day so I really shouldn't be bothering myself with the 17/19 debate. Today I'll do your bedding technique and then try locking up the brakes to see what the distribution is like. She is now safety certified and plated so I don't have to be watching over my shoulder for cops (IMG:style_emoticons/default/smile.gif) |
Eric_Shea |
Aug 5 2011, 07:18 AM
QUOTE I should probably just bite the bullet and buy a new 17. Brake travel never bothered me back in the day so I really shouldn't be bothering myself with the 17/19 debate. I would just go 19mm. The feel is negligible and it's for the better. The cost is much less. Let me know what you find with the bedding process. |
swl |
Aug 6 2011, 04:59 PM
Took her for a bit of an extended drive today (been a LONG time (IMG:style_emoticons/default/smile.gif) ) but I only used the brakes normally. Although it improved greatly from the first set of stops there is enough bothering me that I don't want to stress them just yet. Going back up on the jackstands to get the softlines replaced, Since I've gone this far I might as well to the MC as well and have it new from stem to stern.
Been years in the making - another week or two to be safe is worth it. But damn I WANT TO DRIVE this sucker. |
swl |
Aug 21 2011, 09:48 AM
I have the soft line in hand now. Had the flare nuts soaking in PB laster for about 24 hours. I can only get one nut to break. I'm a bit paranoid about stripping them.
Is it ok to use heat on them? MAPS ok? Right now I'm using a standard 11mm flare nut wrench that is pretty short. What is the concensus on using a crows foot and breaker bar? That would give the leverage I need but might be a quick way to stripping it. |
ChrisFoley |
Aug 21 2011, 10:12 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Try tightening the fitting slightly before loosening it.
You might break any corrosion in the threads loose that way, thus making it easier to disassemble. If you're going to replace the hoses anyway, you can cut them close to the fitting and you may be able to use a more effective wrench that way. |
swl |
Aug 27 2011, 01:03 PM
well I got it off without stripping the nut.
The threads not so much ... A novel way to screw up. |
Aug 27 2011, 01:07 PM
Consider replacing the hard lines also at this point.
For the soft lines, cut then with wire cutters right up next to the fitting and use a 6 point deep socket to get them off. Rich |
swl |
Aug 27 2011, 01:17 PM
but the nut that is giving me grief is the small one on the hard side.
new hard line is the only answer of course. Those threads won't hold anything. This is on the wheel side so it shouldn't be to bad. |
Aug 27 2011, 01:31 PM
If you make the decision, just replace the hard lines at the same time and then you will know the threads are good.
Again, cut them and use a socket....lots easier. Rich |
swl |
Aug 27 2011, 01:55 PM
live and learn I guess. The amount of time I spent trying to save the hardlines is probably way more than I'll spend learning to form a hardline.
76-914 |
Aug 27 2011, 02:27 PM
I agree with Rich. F**k it, cut it, deep socket and if it even looks at me wrong I torch it.
VaccaRabite |
Aug 27 2011, 04:53 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
replace the hardlines. its an afternoon job, and the piece of mind is worth it. I have never been able to part 30+ year old brake lines without the threads going. They may have never been removed before.
Zach |
swl |
Aug 28 2011, 07:35 AM
I agree with Rich. F**k it, cut it, deep socket and if it even looks at me wrong I torch it. (IMG:style_emoticons/default/hide.gif) |
McMark |
Aug 28 2011, 11:29 AM
Replace the hard lines. I usually break those flare nuts free using... *GASP* ViceGrips. Gotta get them really tight the first time. Gotta bounce/surge by applying short bursts of pressure. I never simply push hard..harder..harder. The surging is the key. I've used this technique on TONS of brake lines and have never damaged a flare nut. There is absolutely a risk in using this technique, but if applied correctly, it works. |
Lo-Fi Version | Time is now: 16th May 2024 - 01:11 PM |
