Won't turn after hot, Where's the thread with the start prob |
p914 |
Aug 7 2011, 06:33 PM
Senior Member Group: Members Posts: 518 Joined: 7-September 03 From: Sunny South Florida Member No.: 1,117 Region Association: None |
I remember something about grounds separating when hot. (ie hot/cold short)
It will push start. I can hear the fuel pump and the radio and dash lights come on but the engine won't turn. |
Aug 7 2011, 06:45 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
dirty grounds
p914 |
Aug 7 2011, 06:47 PM
Aug 7 2011, 06:50 PM
battery, (both posts), tranny strap.
The issue is you have a 40 year old starter that is drawing more current with age and corrosion. Clean up the starter and all will be fine. You can use the "hot start" setup which is a ford relay, but its just masking the issues. Rich |
p914 |
Aug 7 2011, 06:51 PM
battery, (both posts), tranny strap. The issue is you have a 40 year old starter that is drawing more current with age and corrosion. Clean up the starter and all will be fine. You can use the "hot start" setup which is a ford relay, but its just masking the issues. Rich Thanks, I'll try cleaning the tranny strap, I already cleaned the posts and the starter is only a couple years old. |
p914 |
Aug 7 2011, 07:49 PM
Well it was the neg battery connection on the post. I recleaned both sides of one of the connections and it starts now. I did clean the strap although since the engine was rebuilt 2 years ago it was still pretty clean but I did it anyway,.
Thanks Rich! (IMG:style_emoticons/default/beerchug.gif) |
Razorbobsr |
Aug 13 2011, 11:59 AM
Member Group: Members Posts: 282 Joined: 6-June 10 From: Terre Haute Ind Member No.: 11,813 Region Association: Upper MidWest |
battery, (both posts), tranny strap. The issue is you have a 40 year old starter that is drawing more current with age and corrosion. Clean up the starter and all will be fine. You can use the "hot start" setup which is a ford relay, but its just masking the issues. Rich |
Kirmizi |
Aug 13 2011, 12:22 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Like Ron (SLITS) mentioned in the other thread, check your ignition switch.
All sorts of funky things can happen if it's bad. Mike |
nsr-jamie |
Aug 14 2011, 08:09 AM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
Does this problem only happen in the summer? Does your car have carbs or injection? I am thinking carbs.....
Razorbobsr |
Aug 14 2011, 09:48 AM
p914 |
Aug 14 2011, 11:10 AM
SDS EFI. no carbs
SUNAB914 |
Aug 14 2011, 01:04 PM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
ignition switch or bad ground.
stewteral |
Aug 14 2011, 01:26 PM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
I remember something about grounds separating when hot. (ie hot/cold short) It will push start. I can hear the fuel pump and the radio and dash lights come on but the engine won't turn. Hey p914, After you check all the previous GOOD suggestions and have no improvement, you might look into an MSD ignition box. I've had one running on my 383 Chevy conversion and it fires EVERY TIME even when the old starter was weak! My thought is that when the starter turns over it draws 300 Amps and thus may starve you old stock ignition of enough voltage to generate a good spark. The situation is exacerbated by heat that effects the coil. Best of luck, Terry |
KELTY360 |
Aug 14 2011, 01:47 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
p914 |
Aug 14 2011, 02:06 PM
I remember something about grounds separating when hot. (ie hot/cold short) It will push start. I can hear the fuel pump and the radio and dash lights come on but the engine won't turn. Hey p914, After you check all the previous GOOD suggestions and have no improvement, you might look into an MSD ignition box. Best of luck, Terry Thanks Terry, I already have an MSD on mine. I'm thinking ground or ignition switch at this point. I was out the other day after I had cleaned my connections at the battery and strap (to which I got the thing to start and thought....problem solved) and it happened again. (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/mad.gif) My engine was rebuilt about 2 years ago and it's SDS EFI 2.7L with MSD. The starter is also about 2 years old. The ignition switch however, I don't know. I believe it's the same one I've always had. I'm going to check the wiring to my battery and maybe redo all the cables and connections to see what happens. (IMG:style_emoticons/default/stirthepot.gif) |
Drums66 |
Aug 14 2011, 02:26 PM
battery, (both posts), tranny strap. The issue is you have a 40 year old starter that is drawing more current with age and corrosion. Clean up the starter and all will be fine. You can use the "hot start" setup which is a ford relay, but its just masking the issues. Rich .......that's a good place to start! (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
p914 |
Oct 17 2011, 09:32 PM
Well, the mystery issue reared its ugly little head last week and I finally nailed it. I turn the key in the ignition. Turn on the headlights and turn the key to crank and the headlights go out and no crank. The troubleshooting section of the manual sez there is a loose connection problem. Sho nuff, the little brown wire on the solenoid was having a hot cold short issue. Even though i thought I had it licked back a while ago having cleaned the connections to the starter and solenoid with no success and then cleaning the negative battery terminal connectors and experiencing success. (thought it was that battery connector...BUT NOOOOOOoooooooo)
So, let's hope this thang is licked now. |
Tom |
Oct 18 2011, 04:20 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Little brown wire on the solenoid? Starter solenoid has a large yellow- to spade terminal, larger red and very large black on nutted post. No brown! Maybe someone did some rewiring that is becoming defective.
Tom |
SUNAB914 |
Oct 18 2011, 08:02 AM
Remember, when ignition switch cools again, it will all work like normal, but this situation will continue to degrade over time.
p914 |
Oct 18 2011, 02:21 PM
I let the car sit for the weekend and tried to start it but no go. So the switch was cooled for about 3 days. Only time will tell.
Lo-Fi Version | Time is now: 21st May 2024 - 08:31 AM |
