URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 127,448 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Now install a new bi-metal blade. put on my gloves and glasses and ..... (IMG:style_emoticons/default/sawzall-smiley.gif)
Two pounds of sheet metal hits the floor. (love that sound) Attached image(s) ![]() |
URY914 |
(IMG:style_emoticons/default/sawzall-smiley.gif) is by Porter Cable
Blade by Dewalt Attached image(s) ![]() |
URY914 |
Mock up again.
URY914 |
Better fit now. I sanded the glass thinner so it will conform to the shape of the car.
URY914 |
front with out the 3/16" gap
URY914 |
Next I'll use some sheet metal screws to hold it in place and I'll start grinding/sanding it expose the metal. This will allow for a solid bond of the glass.
I could have made a mold of only the sheetmetal that was not cut out. Than I would 'glass the flare to it. But this way I will have a entire q-panel mold when I'm done. Stay tuned, boys and girls Your friend, Paul |
URY914 |
Ok, its been about a month, four hurricanes and a screwed up 'puter. But I didn't stop working in the garage. I glassed the flare to the metal. (I guess I didn't take any pics of the fender before I installed the flare, sorry) This is the first ROUGH layer of bondo. 90% of this gets sanded off.
URY914 |
rear view
URY914 |
glaze or crack filler in red
machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
URY914 |
Primed and in the sun
URY914 |
Nice FAT rubber. 225/50's
URY914 |
I've got 1/2" spacers on the rear and about 1/4" between the fender and the tire.
URY914 |
from the top
URY914 |
Today.
URY914 |
Let do the left side, shall we...
Mark out the cut line. Attached image(s) ![]() |
URY914 |
Grind/sand away the bondo...I mean paint so to get a good bond with the glass.
URY914 |
Looking to the front.
URY914 |
Fitting in the glass mat strips. you can see them laying on top.
URY914 |
Here it is with the glass bonded over the flare and the fender.
Lo-Fi Version | Time is now: 12th July 2025 - 02:09 PM |
