matrixops |
Newbie ![]() Group: Members Posts: 16 Joined: 8-July 04 From: Overland Park,KS Member No.: 2,323 ![]() |
I thought I had some experience with glassing from my days working on UAV's in the Marine Corps, but you have some great skill. Seeing all the work and the finished product is inspiring me to get my hands a little dusty.
Keep us up to date on the progress. MatrixOps |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 127,448 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
I told Gunnar I only work on 914's. None of that 917, 908, 904, 910 crap for me (IMG:style_emoticons/default/w00t.gif)
Thanks everyone, I 'll keep posting as I progress. Paul |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,633 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
So when can I bring my car by for a f/g 'makeover' ? Nice work Paul...please keep us posted...and PM me if you are potentially interested in building fenders or doors for my "914R" project (IMG:style_emoticons/default/w00t.gif)
URY914 |
Tonight I took it off the jackstands (I love it when I say that) and rolled it out for a looksee. Needed to see how it all looks with it on the ground. The wheels (or rims for the under 30 guys) were installed with a 1/4" spacer to get them out a little more. As you can see, there's now a lot of tire showing.
Attached image(s) ![]() |
URY914 |
A little closer...
URY914 |
and the rough right side.
URY914 |
from the top
URY914 |
PROBLEM!!!
Tire hits the fender when I crank it over to the right. Attached image(s) ![]() |
URY914 |
From the inside.
Nothing a 50 grit sanding disk won't take car of. (IMG:style_emoticons/default/biggrin.gif) Attached image(s) ![]() |
URY914 |
I like it a whole lot more with the flares.
URY914 |
Looks meaner... (IMG:style_emoticons/default/mad.gif)
URY914 |
another angle.
This weekend I'll glass back in the left side inner fender panel. That keeps rocks from hitting me in the face. When you take the door post out, there is a big hole that is left so I had to make a panel to cover it. Attached image(s) ![]() |
URY914 |
For you new guys, this what it looked like right after painting. My "narrow bodywork" look. This was for the top speed runs at Bonnieville. (IMG:style_emoticons/default/cool_shades.gif)
Ain't it preeeety? stay tuned, Paul Attached thumbnail(s) ![]() |
URY914 |
I sanded down the inside and added back in some strips of glass mat. After sanded on the outside it was getting a little thin so I added this material to the inside.
URY914 |
more of the same. The resin is sorta red before it sets up.
URY914 |
I had area that I needed to fill where the flare didn't meet the rocker panel. So I had to glass it in.
URY914 |
This is the outside after I removed the tape. I'll have to sand this whole area down to get it to make the transition between the door and the flare. Than I'll have to maintain the seam of the rocker panel to the door/fender. I'm not going to taper the rocker panel ends out to meet the flares. If it was a street car I'd do it. Once you see a car with flared rockers it adds a nice finishing touch and completes the look.
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Rockin' Paul! Looks like master grade work.. as you've had much practice.
(IMG:style_emoticons/default/smilie_pokal.gif) Miles |
URY914 |
Thanks Little Buddy!
Once you learn a few tricks its pretty easy. And besides, if you screw up you're just a sanding disc away from trying again. (IMG:style_emoticons/default/biggrin.gif) Paul |
john rogers |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 ![]() |
Damm, looks really good. Now I remember why I riveted mine on..... Of course you know a car with flares is slightly slower than one without due to the added frontal area?
Lo-Fi Version | Time is now: 12th July 2025 - 02:09 PM |
