CDI Box Help! |
CDI Box Help! |
RiqueMar |
Aug 11 2011, 06:21 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
I'm in desperate need of help with this CDI wiring on my conversion. The wiring I pulled off the 77' is just in horrible condition, as you will see in the pictures below, and I wouldn't be surprised if the wires are colored wrong or spliced wrong.
I'm not sure where each of the leads go, and I can't seem to find anything on an assortment of diagrams. (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1313108475.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1313108475.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1313108476.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1313108476.4.jpg) |
904svo |
Aug 11 2011, 08:38 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Check out this article it's on 6pin and 3 pin cdi boxes.
http://forums.pelicanparts.com/porsche-911...umentation.html |
IronHillRestorations |
Aug 11 2011, 08:49 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I don't have any of my wiring diagrams here at home, but the red one should be switched power, one goes to the points/tach, and the other goes to the ignition transformer (which looks like a coil but isn't).
Cap'n Krusty |
Aug 11 2011, 08:53 PM
I have a pretty nice original harness if you want it, exchange. PM me for a price.
The Cap'n |
RiqueMar |
Aug 12 2011, 08:30 AM
I don't have any of my wiring diagrams here at home, but the red one should be switched power, one goes to the points/tach, and the other goes to the ignition transformer (which looks like a coil but isn't). Thanks Perry, would you mind checking when you get a chance? It would be most appreciated as this is the last article of concern in my Engine bay wiring. I have a pretty nice original harness if you want it, exchange. PM me for a price. The Cap'n Thanks Cap, but I'm just about done with my converted one, and I'm taking this challenge personally, I wanna conquer this thing! (IMG:style_emoticons/default/ar15.gif) |
SLITS |
Aug 12 2011, 02:02 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Four wire to a 3 pin CDI box. Look at the end of the box ... terminals are labeled "A", "B" & "C"
"A" = to Terminal 15 on transformer (not an effin' coil). "B" = Switched power B+ "C" = Tach input & trigger wire from points Last wire CDI case to ground (spade terminal) |
RiqueMar |
Aug 12 2011, 02:03 PM
Four wire to a 3 pin CDI box. Look at the end of the box ... terminals are labeled "A", "B" & "C" "A" = to Terminal 15 on transformer (not an effin' coil). "B" = Switched power B+ "C" = Tach input & trigger wire from points Last wire CDI case to ground (spade terminal) Is this the part where you slap me in the back of the head and say, 'Don't make me have to tell you again, kid" Thanks Ron! |
SLITS |
Aug 12 2011, 03:12 PM
Four wire to a 3 pin CDI box. Look at the end of the box ... terminals are labeled "A", "B" & "C" "A" = to Terminal 15 on transformer (not an effin' coil). "B" = Switched power B+ "C" = Tach input & trigger wire from points Last wire CDI case to ground (spade terminal) Is this the part where you slap me in the back of the head and say, 'Don't make me have to tell you again, kid" Thanks Ron! I was thinking more of a kick and not in the back of the head. The connector in your pic had a mate and probably is the tach wire / B+ if there are 2 wires. Long harness went to transformer / dizzy (other side of transformer goes to ground - Terminal 1). Lonely wire is the ground on the CDI case. |
RiqueMar |
Aug 15 2011, 09:35 AM
Four wire to a 3 pin CDI box. Look at the end of the box ... terminals are labeled "A", "B" & "C" "A" = to Terminal 15 on transformer (not an effin' coil). "B" = Switched power B+ "C" = Tach input & trigger wire from points Last wire CDI case to ground (spade terminal) Is this the part where you slap me in the back of the head and say, 'Don't make me have to tell you again, kid" Thanks Ron! I was thinking more of a kick and not in the back of the head. The connector in your pic had a mate and probably is the tach wire / B+ if there are 2 wires. Long harness went to transformer / dizzy (other side of transformer goes to ground - Terminal 1). Lonely wire is the ground on the CDI case. Ok, so I've started pulling everything out, and I'm sure I'll have to do some work on this portion of the harness, as you've seen, it's pretty rough. Just have a few more questions... I have the Red wire going to the positive terminal on the battery, my only issue now is that I don't know which of the white wires is which, because I have a Permatune Box and the numbers/letters don't seem to be there (IMG:style_emoticons/default/blink.gif) Was this the connector you where talking about, Ron (see first picture)? (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1313422499.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1313422499.2.jpg) |
Cap'n Krusty |
Aug 15 2011, 09:44 AM
That's not a CD unit, it's a Permadoom. Use it and, sooner or later, you'll be walkin'.
The Cap'n |
GeorgeRud |
Aug 15 2011, 10:56 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Weren't the blue ones OK? I thought it was the later ones that had the problems (but I certainly could be wrong!). My Bosch CD is still humming along, but I hate to see what it costs to have one rebuilt these days.
Are more and more people switching over to the MSD or other ignition systems as the original ones are giving up? |
SLITS |
Aug 15 2011, 11:24 AM
Wiring on the "Permadoom" is the same. My 2.7L runs better with the "Permadoom" than it does with the Bosch. "Permadoom" was OE to Porsche when Bosch couldn't get their act together.
Cost to rebuild a Bosch unit is $225 & up. Supposedly, the "Permadoom" cannot be rebuilt as it is potted. Never took one apart to find out. |
RiqueMar |
Aug 15 2011, 12:12 PM
Awesome!
And what about that plug that I was talking about? Can I eliminate it and am I correct in the red going to the positive terminal? Pelican sells a 'Permatune Coil' will I need one or can I stick with the original black unit? I know, I know, I'm a bottomless pit of "how" and "why" questions (IMG:style_emoticons/default/smile.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1313422499.1.jpg) |
SLITS |
Aug 15 2011, 12:38 PM
Use a stock "TRANSFORMER - it's not a coil.
Yes you can cut the plug off and wire in (not the plug that goes into the CD unit). |
RiqueMar |
Aug 15 2011, 12:58 PM
Use a stock "TRANSFORMER - it's not a coil. Yes you can cut the plug off and wire in (not the plug that goes into the CD unit). Yes, I meant the one below with the black overspray on it. (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1313422499.1.jpg) |
SLITS |
Aug 15 2011, 01:43 PM
And that's the one I meant. You probably could find a mating plug if you looked though.
As a side note, I carry a spare CDI unit at all times. |
RiqueMar |
Sep 5 2011, 08:11 PM
Reference for anyone else who stumbles upon this, correct? (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1315275065.1.jpg) |
SLITS |
Sep 6 2011, 07:05 AM
Si!
Lo-Fi Version | Time is now: 20th May 2024 - 09:21 AM |
