distributor driveshaft pictures, Did I screw up 15 years ago?? |
dimmer |
Jul 7 2004, 09:10 AM
Newbie Group: Members Posts: 18 Joined: 22-August 03 From: Oakville, Ontario Member No.: 1,060 |
A few months ago someone posted pictures of the distributor driveshaft. Does anyone remember them.
15 years ago I rebuilt my motor and ever since that posting I could not remember if I ever replaced the washer that goes on the ledge. This weekend i pulled the distributor shaft and no washer. Does anyone know if it needed on all cars? I read in the Haynes that some cars had them. Mine is a stock 74 1.8 thanks |
DNHunt |
Jul 7 2004, 09:54 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Here's a picture of the dizzy shaft in a case I'm working on. I think it's there to protect the thrust surface of the case. I would think it's a good thing to have. There are 3 little depressions machined into the washer for oiling I suspect.
Dave Attached image(s) |
DNHunt |
Jul 7 2004, 09:55 AM
Washer with 3 depressions
Attached image(s) |
Jake Raby |
Jul 7 2004, 11:07 AM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Yes, it is a requirement... You are lucky that the dizzy stayed fully engaged and did not slip its drive!
I have seen cases chewed up terribly from not running them. |
Lo-Fi Version | Time is now: 14th May 2024 - 08:31 AM |
