What kind of HP for 2258? |
tornik550 |
Aug 22 2011, 12:23 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
Just curious- what kind of HP do you think I will get from my 2258 build? I realize there are a lot of variable but just looking for opinions. This is really irrelevant- just curious.
78mm crank 96mm pistons 5.4" con rods 2.0l heads ported with 44/36valves cam- .507 lift, duration 298, duration at ..50 262 dual weber 44idf's stock 2.0l headers (I have others on order) |
Elliot Cannon |
Aug 22 2011, 01:06 PM
I have 96 pistons, 76 crank, not sure about cam and con-rods 44idf Webers. F11 emulsion tube, 130 main jets, 175 air jets. The engine was built by FAT Performance in Orange California and produced 147 HP on the Dyno. Good luck.
Cheers, Elliot |
tornik550 |
Aug 22 2011, 02:31 PM
I have 96 pistons, 76 crank, not sure about cam and con-rods 44idf Webers. F11 emulsion tube, 130 main jets, 175 air jets. The engine was built by FAT Performance in Orange California and produced 147 HP on the Dyno. Good luck. Cheers, Elliot Excellent- just what I am looking for. Anyone have one that they built and know the hp numbers? I suppose HP shouldn't be effected too much by my crappy engine building skills- just mainly reliability. |
Jake Raby |
Aug 22 2011, 09:03 PM
Jake Raby |
Aug 22 2011, 09:12 PM
I tried to upload more, but it keeps timing out
This post has been edited by Jake Raby: Aug 22 2011, 09:16 PM |
tornik550 |
Aug 23 2011, 03:28 PM
Wow, those are some impressive numbers.
I'm thinking that I will be far from those numbers. |
Lo-Fi Version | Time is now: 15th May 2024 - 02:08 PM |
