building a 1911 from a 1.7, will my existing heads work? |
bradtho |
Aug 22 2011, 11:18 PM
Member Group: Members Posts: 266 Joined: 22-December 09 From: Seattle, WA Member No.: 11,165 Region Association: None |
I'm thinking about taking my stock 1.7 to a 1911. Some old threads seem to suggest that you can't do this with the 1.7l heads, while others seem to suggest it's fine. Can anybody set me straight on if I would need new heads, if they'd need to be machined, or if I'm good to go?
Also, I've got 2 engines all with original german cylinders. Am I better off taking the best 4 and boring them out or going with new chinese cylinders (local shop recommends QSC). I've been thinking if I've got 4 decent ones that the OE cylinders would likely be better than the chinese stuff. anything else I should be thinking about? |
VaccaRabite |
Aug 23 2011, 07:01 AM
En Garde! Group: Admin Posts: 13,437 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
My 2056 uses 1.7 heads. It can be done.
That said... I'd not do it this way again. When I got the engine it already had the cut heads so I kept them. If I were starting new i would get better heads. |
Lo-Fi Version | Time is now: 5th May 2024 - 03:34 PM |
