building a 1911 from a 1.7, will my existing heads work? |
bradtho |
Aug 22 2011, 11:18 PM
Member Group: Members Posts: 266 Joined: 22-December 09 From: Seattle, WA Member No.: 11,165 Region Association: None |
I'm thinking about taking my stock 1.7 to a 1911. Some old threads seem to suggest that you can't do this with the 1.7l heads, while others seem to suggest it's fine. Can anybody set me straight on if I would need new heads, if they'd need to be machined, or if I'm good to go?
Also, I've got 2 engines all with original german cylinders. Am I better off taking the best 4 and boring them out or going with new chinese cylinders (local shop recommends QSC). I've been thinking if I've got 4 decent ones that the OE cylinders would likely be better than the chinese stuff. anything else I should be thinking about? |
jmill |
Aug 26 2011, 06:31 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Found it. http://www.914world.com/bbs2/index.php?sho...891&hl=1911
Damn - only the dyno sheet. There's one out there where Jake spells out the combo. |
7275914911 |
Aug 27 2011, 10:00 AM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
Found it. http://www.914world.com/bbs2/index.php?sho...891&hl=1911 Damn - only the dyno sheet. There's one out there where Jake spells out the combo. Try this one.... 1911 Recipe |
Lo-Fi Version | Time is now: 6th May 2024 - 02:29 AM |
