building a 1911 from a 1.7, will my existing heads work? |
bradtho |
Aug 22 2011, 11:18 PM
Member Group: Members Posts: 266 Joined: 22-December 09 From: Seattle, WA Member No.: 11,165 Region Association: None |
I'm thinking about taking my stock 1.7 to a 1911. Some old threads seem to suggest that you can't do this with the 1.7l heads, while others seem to suggest it's fine. Can anybody set me straight on if I would need new heads, if they'd need to be machined, or if I'm good to go?
Also, I've got 2 engines all with original german cylinders. Am I better off taking the best 4 and boring them out or going with new chinese cylinders (local shop recommends QSC). I've been thinking if I've got 4 decent ones that the OE cylinders would likely be better than the chinese stuff. anything else I should be thinking about? |
914work |
Nov 2 2017, 02:18 PM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
Resurrection:
No one appeared to answer the question for sourcing the small dia. P&C's referred to? Pin height? Off the shelf or custom? The other related question is the 78.4mm rod length, is that an existing Rod from another application or a custom rod? I ask because I have 3 or 4 core 1.7L's hanging around here & I should do SOMETHING with them... |
Lo-Fi Version | Time is now: 6th May 2024 - 01:54 AM |
