building a 1911 from a 1.7, will my existing heads work? |
bradtho |
Aug 22 2011, 11:18 PM
Member Group: Members Posts: 266 Joined: 22-December 09 From: Seattle, WA Member No.: 11,165 Region Association: None |
I'm thinking about taking my stock 1.7 to a 1911. Some old threads seem to suggest that you can't do this with the 1.7l heads, while others seem to suggest it's fine. Can anybody set me straight on if I would need new heads, if they'd need to be machined, or if I'm good to go?
Also, I've got 2 engines all with original german cylinders. Am I better off taking the best 4 and boring them out or going with new chinese cylinders (local shop recommends QSC). I've been thinking if I've got 4 decent ones that the OE cylinders would likely be better than the chinese stuff. anything else I should be thinking about? |
Dave_Darling |
Nov 2 2017, 05:28 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Check with AA Pistons. The 90.5 were a stock replacement overbore part, at least in theory.
When you talk about the rod length, do you mean "rods for a crank that has a 78.4mm stroke"? If so, I believe those cranks are usually ground with Type I journals, or sometimes with Rabbit journals. There are a lot of aftermarket rods you can get for either of those motors. --DD |
Lo-Fi Version | Time is now: 5th May 2024 - 10:55 PM |
