building a 1911 from a 1.7, will my existing heads work? |
bradtho |
Aug 22 2011, 11:18 PM
Member Group: Members Posts: 266 Joined: 22-December 09 From: Seattle, WA Member No.: 11,165 Region Association: None |
I'm thinking about taking my stock 1.7 to a 1911. Some old threads seem to suggest that you can't do this with the 1.7l heads, while others seem to suggest it's fine. Can anybody set me straight on if I would need new heads, if they'd need to be machined, or if I'm good to go?
Also, I've got 2 engines all with original german cylinders. Am I better off taking the best 4 and boring them out or going with new chinese cylinders (local shop recommends QSC). I've been thinking if I've got 4 decent ones that the OE cylinders would likely be better than the chinese stuff. anything else I should be thinking about? |
914work |
Nov 2 2017, 08:51 PM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
About 30 years ago (IMG:style_emoticons/default/rolleyes.gif) I had a 1776cc type 1 (Beetle) which was 69 x 90.5. They were CIMA pistons. Could this be what this old thread was referring to? (IMG:style_emoticons/default/confused24.gif) I was unaware a T1 cylinder could be mated to a T4 case. Arent the registers ..smaller? @Dave yes I should have used "Rods / crank to attain" a 78.4mm stroke. So as Jake likes to say , its all in the Combo...? |
Montreal914 |
Nov 2 2017, 09:16 PM
Senior Member Group: Members Posts: 1,544 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
About 30 years ago (IMG:style_emoticons/default/rolleyes.gif) I had a 1776cc type 1 (Beetle) which was 69 x 90.5. They were CIMA pistons. Could this be what this old thread was referring to? (IMG:style_emoticons/default/confused24.gif) I was unaware a T1 cylinder could be mated to a T4 case. Arent the registers ..smaller? @Dave yes I should have used "Rods / crank to attain" a 78.4mm stroke. So as Jake likes to say , its all in the Combo...? I was only referring to the pistons being 90.5mm. I don't think type 1 cylinders would fit a type 4 engine. |
Lo-Fi Version | Time is now: 5th May 2024 - 05:08 PM |
