building a 1911 from a 1.7, will my existing heads work? |
bradtho |
Aug 22 2011, 11:18 PM
Member Group: Members Posts: 266 Joined: 22-December 09 From: Seattle, WA Member No.: 11,165 Region Association: None |
I'm thinking about taking my stock 1.7 to a 1911. Some old threads seem to suggest that you can't do this with the 1.7l heads, while others seem to suggest it's fine. Can anybody set me straight on if I would need new heads, if they'd need to be machined, or if I'm good to go?
Also, I've got 2 engines all with original german cylinders. Am I better off taking the best 4 and boring them out or going with new chinese cylinders (local shop recommends QSC). I've been thinking if I've got 4 decent ones that the OE cylinders would likely be better than the chinese stuff. anything else I should be thinking about? |
Dave_Darling |
Jun 26 2015, 08:49 AM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
It'll require some tweaking of the MPS, and possibly other adjustments.
--DD |
MikeInMunich |
Apr 12 2020, 12:34 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
It'll require some tweaking of the MPS, and possibly other adjustments. --DD I am running D-Jet on a 1911. Without modification, it actually did work well, but then I ran into a problem as my MPS diaphragm deteriorated and the vacuum seal became more compromised. Naturally that would cause a problem no matter what. But when I put in a refurbished MPS with a perfect seal I had the same hesitation Problem only much worse, about which there is a thread here that I began, and the solution was to swap the yellow 1.7 injectors to the higher volume green ones which came with the 2.0 Liter D-Jet. So, apparently, the fact that it worked well at first seems to perhaps been a fluke, with the imperfect MPS vacuum seal having been coincidentally in just the right „range“ that the system sent out a mixture that worked well for the 1911 displacement. |
Lo-Fi Version | Time is now: 5th May 2024 - 11:15 PM |
