it dont sound right, engine making sqeaking noise |
sanman |
Jul 11 2004, 08:47 PM
Leaving California Group: Members Posts: 341 Joined: 17-June 04 From: Houston, TX Member No.: 2,219 Region Association: None |
hi to all. got engine started after 3 mo it sounds ok but there is a occasional sqeakin noise followed by an immediate miss. looking for a place to start. im thinking maybe a valve or lifter or distributor. any help is appreciated.
ok here is a list of details: engine size 1.8 valves set at 006 ex 008 intake oil kendal 20w 50 noise fades or lessen often when engine is warm i need to get on the road hope it nothing serious, if it is will someone lend me a 6 or v8 914 until it is running (IMG:style_emoticons/default/driving.gif) |
SLITS |
Jul 11 2004, 09:08 PM
1. point rubbing block on dizzy cam
2. loose metal around alternator 3. Lots of blowby causing "squeak/tweet" from pressure being relieved at rear main seal. 4. Bad alternator bearing. 5. Mouse in squirrel cage blower not being fed. 6. Slipping alternator drive belt. |
sanman |
Jul 11 2004, 09:28 PM
bigggg thanks!!! I will feed the mouse tonight and the rest tomorrow. (IMG:style_emoticons/default/idea.gif)
dimmer |
Jul 12 2004, 05:47 AM
Newbie Group: Members Posts: 18 Joined: 22-August 03 From: Oakville, Ontario Member No.: 1,060 |
Check your valve clearances they should both be the same on the 1.8l. the book says 0.6
Jul 12 2004, 09:49 AM
Resident German Group: Admin Posts: 41,661 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(dimmer @ Jul 12 2004, 04:47 AM) Check your valve clearances they should both be the same on the 1.8l. the book says 0.6 actually, set 'em to 004 all around. that'll give you some extra "punch" once the engine is running ok again ... (IMG:style_emoticons/default/wink.gif) Andy |
Lo-Fi Version | Time is now: 28th May 2024 - 08:00 PM |
